Bouba
Without watertight bulkheads the water will slosh around
The boat goes down nose first. I would have expected that if the rudder stock was ripped out and water was entering from the stern then the stern would start to go down. That's strange.
But normally the water is coming in from the stern in these attacks. Its normally the rudder that gets damaged.Not really. These modern boats that carry almost maximum beam all the way to the transom have a lot of buoyancy aft, whereas the bow has much lower volume.
I have a Sun Odyssey 349. The doors to the aft cabins seal very well (they have a weather strip type seal all the way around).
If the doors to the two aft cabins and the hatches and vents were shut it would create quite a reserve of buoyancy aft.
The bow meanwhile has the windlass, anchor chain and a 210 litre water tank (which until the inflooding water reaches its top would weigh the bow down.
Without a rudder...no control...you stuff the next wave...all the water in the boat runs forward....But normally the water is coming in from the stern in these attacks. Its normally the rudder that gets damaged.![]()
Exactly. Just because water is coming in at the stern doesn’t mean it’s the stern that sinks first.Without an a rudder...no control...you stuff the next wave...all the water in the boat runs forward....
I doubt that there have been any flip up rudder boats attacked ie 16 to 24foot LOA it's boats in the 30 foot plus LOA that have fallen prey to ORCA because they sail in waters rarely frequented by small vessels.How many of us do not regularly practice sailing with no rudder (flip up rudders)
I for one am guilty.
I am guessing that whom ever comes up with a solution to protect rudders will do very well financially.
Maybe something like in JAWS that makes a high pitched noise under water!!!
There’s your answer….don’t get an all white boatGreat Whites are also the prey of Orcas which are the marine apex predator.
No more will my green sea...There’s your answer….don’t get an all white boat
For those that haven't seen Booba here's a photo of himView attachment 199570
Thats Real BoubaThat couldn't possibly be Bouba, no Diet Coke.
Not black AND white....the orca might try to hump itNo more will my green sea...
Might get a bit hot though
For the Newport to Bermuda Race, each yacht is required to have, and practice with, a system for steering the boat if the rudder is lost.How many of us do not regularly practice sailing with no rudder (flip up rudders)
