Old shaft coupling?
Ian_Edwards
9 Feb 2002
Aberdeen Scotland
This is one of 4 couplings off a volvo MB2D, probably about 50 years old.
The rubbber has debonded on all 4.
Any idea if it is still possible to find replacement?
Ian_Edwards
9 Feb 2002
Aberdeen Scotland
I don't know the name of the coupling.
The coupling is in the form a cup, a very rusty cup. The rubber was bonded into the cup.1000010839.jpg
The stud on one side is welded on to the cup. On the inside of the cup there's a rubber bush with, which should be bonded to the cup, and a stud bonded into the centre of the bush. There's no metal to metal connection between the two studs.
Ian_Edwards
9 Feb 2002
Aberdeen Scotland
No, surprisingly, they aren't engine mounts. They are a coupling between the gearbox and the propshaft.
There are 4 of the couplings between the flange on the shaft and the gear box flange.
They take the place of the 4 bolts you'd normally expect.
It's like a simple form of R&D coupling
Perplexing, I've yet to find anyone who has seem this arrangement before.
It could be that it's an improvised coupling, made from engine mounts.
It's off an old boat which was towed into the pontoon over the weekend having lost all drive. The owners are new to the boat and sailing. They are struggling to get it repaired, I'm just trying to help.
Tranona
10 Nov 2007
I seem to remember Dylan Winter (Keep Turning Left) having grief with that style of coupling on the old Volvo in his Mirror Offshore and not being able to find a direct replacement. replacement Had a look on his site to see if there was anything on his trials and tribulations with the beast but he seems to have removed it all.
Ian_Edwards
9 Feb 2002
Aberdeen Scotland
I thought about glueing the bushes back into the cups, as a temporary measure, but the local enginer has sawed through one of the studs to get it out. So that rules that one out
We're along way from any major city, 2hr to Glasgow, 2hr to Inverness. Very limited in what can be sourced locally.
rogerthebodger
3 Nov 2001
So there are 4 of these connected to a drive plate on the gearbox and a matching plate on the prop shaft with 4 of these between the 2 plates
It may be possible to replace these with similar but different design
Details dimensions of the existing and the gap between the drive plates
It also may be possible to bolt a current flexible coupling between the 2 drive plates. Mine is simulate to this arrangement
Plum
6 Jun 2001
UK East Coast
It would be useful if you would post a picture of the other parts of the coupling, which I assume are still connected to the propshaft and gearbox flange.
These any good?
Prop Shaft Coupling Rubber Block for Volvo Penta, Replaces: 803762
Volvo Penta rubber cushion, part number: 803762-4 - Coastalrides
scottie
14 Nov 2001
scotland
Ian_Edwards
9 Feb 2002
Aberdeen Scotland
The problem is now resolved. The local engineering company has source 4 of the original couplings, 3 days delivery.
Thanks for all the suggestions, but fitting replacement couplings is by far the easiest option.
As foot note, I find it amazing that you can get spare parts for a 50 year old engine, on 3days delivery, when I often struggle to source spares for my Yanmar
