OK ... Teaser time ... actually a serious question.
Refueler
13 Sep 2008
Far away from hooray henrys
Take two engines. Both raw water cooled. Boats are now out of water and need Anti freeze through them.
1. Perkins 4-107
2. Yanmar 2GM20
I can supply water via hose if necessary - but am considering whether a 20lt drum with tap at bottom is enough to feed water into raw intake - to get engine warm and then change to Antifreeze. Then once done - drain blocks via the drain taps.
I will not be circulating as I exit water via transom exhaust ....
My thoughts are 20lt would not be enough.
OK ... second idea is to modify the Rydlime idea ... instead of Rydlime - to have container of Antifreeze with controlled flow into raw intake ... collect at exhaust and a bilge pump putting it back into first container .... circulate for reasonable time till fluid is near hot.
Collection from exhaust is easy enough ... a standard domestic large bore pipe propped so exhaust discharges into it ... other end in a bin. This allows gas to vent while fluid is fired into the pipe.
B27
26 Jul 2023
I wouldn't consider it acceptable to exhaust anti freeze into the river.
If you want to circulate stuff, why not rig a hose into the mixing elbow to cool the exhaust, and recirculate the antifreeze before it enters the exhaust? You could even leave it full as a closed circuit over the winter?
How much water stays in your engines if you just drain them?
PaulRainbow
16 May 2016
Suffolk
Who said anti freeze would go in the river ?
For one thing, the boats are on the hard, for another, the OP said "Whatever I do - I need to collect the antifreeze, not let it just blow all over the concrete and into the drain."
PaulRainbow
16 May 2016
Suffolk
1. Perkins 4-107
2. Yanmar 2GM20
I don't think 20lt will be enough, i would go for option 2.
Refueler
13 Sep 2008
As Paul correctly said - I am not allowing it into the river.
Many will have realised by now that I am trying to sort a way of doing this without need to try disturb hoses / fittings that example my Perkins has had undisturbed for many years ,.....
I accept that someone will say - arrrr but chance to descale hoses ... and my answer is : I run my engines colder than spec to precisely reduce all that ...
Hopefully after my meeting with Town Mayor - to give him stick about his Tree Commission refusing my trimming of trees - one of which few days ago - then fell and only just missed the house ....
That main trunk is about 1m diameter ... this is no small tree .. its a Horse Chestnut and OLD .....
Anyway hopefully weather will be ok to have a go at the boats ... probably vent my frustration on them !!
johnalison
14 Feb 2007
Essex
A friend of mine reckoned that you could check the cooling system by his fuel of fifteen. The exhaust should fill half a bucket in fifteen seconds at fifteen hundred RPM. So, if half a 2-gallon bucket is, say, five litres, that should give twenty litres per minute, for our Volvo 2030s. I have absolutely no idea if this is correct.
James_Calvert
6 Oct 2001
I have a very simple approach. I hang a bucket over the side of the boat with a syphon tube stuck into the skin fitting for the raw water intake. I keep the bucket topped up with water whilst the engine is reaching operating temperature, then tip an antifreeze mix for the last couple of minutes or so.
I mainly use a hose for topping up, running just fast enough to keep pace with the engine. But one year the yard tap was about 100m away or so and I thought I'd use some 5 gal water containers I had. I used both and had refilled one before the engine was ready to take the antifreeze. Bit of a dash to the tap...
Next time I joined every hose I could find to reach the tap.
So, 21 litres not enough in my view.
Boathook
5 Oct 2001
Surrey & boat in Dorset.
firewood for next winter.
Refueler
13 Sep 2008
To add to the 15 tons I already have ...
I have a 16kw glass fronted wood fire in the kitchen that heats air box over it - the hot air is then via fan blown to the second floor. Ground floor - the heat from that fire spreads out despite the large rooms ... and if really cold - gas system cuts in.
Met Mayor today - he called Boss of Dept and told him to sort it ... they visit tomorrow to agree more tree topping / crowning. And of course my removal of the half trunk tree left dangerously standing.
