Chiara’s slave
If it’s got moving internal blocks, you might need to take one end off. Selden, for instance. Mine, and many others don't have that, and are simple to re reeve.
I have in the past re-reeved the reefing lines in a number of Z-Spars booms on Glenans 5.70s and, yes the ends had to be taken off. I seem to remember that it was only moderately fiddly and difficult.Exactly, you would need to take the end off and even then it's no so straight forward.
Reefing at the mast, but the lines are inside the boom.I don't think Glenn's 5.70s have single line reefingIf they did I would be very surprised, very surprised indeed. A 5.70 and it's boom are very different beasts to Westerly Storms.
No disrespect, but it may be fine for you but if you read the posting the OP been putting out , I think he may have some difficulty doing it .Getting lines back through an un-moused boom is ok, in my experience. Compared to a mast (=nightmare) it just requires a bit of fiddling and ingenuity. Ours is sitting on the deck waiting for the mast to be restepped and we’re ‘quietly confident’…!
Fair enough, but boat ownership is a steep learning curve (each time?!) and that’s part of why we enjoy it and why we offer advice to others on here. Mine to the OP was more along the lines of - ‘the boom’s off (well done!), which is what you wanted, so don’t worry about the lines etc. (with some random tools and at worse a small weight on a fishing line and a very jaunty angle on the boom - you’ll get them back down any cross-sections, sheaves, etc. eventually). And happy boating - once it comes!
We don’t quite know if the mast is off the boat but presumably if it is no doubt Flipper has worked out a way to get it back on so that might also address any small boom issues. I think we need so photos ideally of the re rigging process. I suspect returning the boom to its normal position might be more entertaining . Now it’s off a good chance to check the quality of all those pulleys etc and how well they run. In my experience in boom reefing can be hard to pull through when reefing but appreciate this might not be a selden boom .
Simple reefing at the mast. The lines emerge through jammers at the front end of the boom and are tensioned on a mast-mounted winch.Simple or single line? There's quite a difference and it would be pointless on a 5.70.
I followed the suggestions and left bom lines in ;-)I hope for your sake you haven't removed any internal reefing lines from the boom.
Well done now you need to establish if they are single or simple reefing for when you come to put the boom on and mainsail and reeve the reefing lines. We will need to know for when you ask us. ? Glad you are coming to grips with it, years of fun and frustration to follow?I followed the suggestions and left bom lines in ;-)
I have never known a mast and boom lifted together, the rigger would fit it for a priceIf the mast is off and will eventually be replaced it might be simplest to fix the boom on at same time then the crane lifting can give flipper a helping hand surely so he does strain himself etc .
I can barely handle my boom (43 footer) so I think that’s a bit harsh. I can just lift it on my own but it’s pretty tricky. And I’m not that old yet!I betting it's the mast , it's got to be one hell of a boom that you can't handle .
Well I could easily manage my boom on my moody 42 without any problem and by what you wrote I'm probably much older then you .I can barely handle my boom (43 footer) so I think that’s a bit harsh. I can just lift it on my own but it’s pretty tricky. And I’m not that old yet!
