Oil & Temp guages
Richard_H
31 May 2001
Hi
Would like to fit oil pressure and water temp guages to the 1985 Volvo 2002 on my Moody 27. Can anyone recommend specific manufacturer and or supplier.
Assume I should not fit domestic car engine type guages - can you get kits with the wiring and sender etc.
Appreciate any help advice.
Many thanks
andy_wilson
S. Yorkshire / Devon
Absolutely no reason not to fit car gauges.
If you seal them in well they are likely to be as water resistant as marine ones (which aren't particularly water resistant).
howardclark
16 Sep 2001
S. Wales
Fitted new faria guages from ASAP last winter - inexpensive and standard hole sizes etc. ASAP were very helpful in getting the sender size right. Just make sure you choose the temperature scale and pressure range you need as per your old gauges.
