Oil on troubled waters?
Leighb
8 Aug 2007
Suffolk
If you read some of the old cruising books they talk about an "oil bag" I think the idea is that you hang that in the water on the windward side. The oil leaks out and creates a smoother area which will always be to windward as the yacht - either lying a-hull or hove to - makes steady leeway.
I have no personal experience you understand. :D
Habebty
Norfolk/Suffolk
I have seen a picture of a reservoir for a hand pumped oil supply on a lifeboat for creating a smooth patch of water in tempestuous seas!
(Buggered if I can remember where though)
Richard10002
17 Mar 2006
Manchester
Fairly sure it works, but it's a long time since I thought about how. Worth a google. Think it sits on the water and minimises breaking and spray.
Giblets
5 Mar 2006
Surrey
That shown in the recent Ade Edmuson tv prog, Ade At Sea. He was in an old lifeboat and pointed out that feature.
prv
29 Nov 2009
Southampton
I have a late-70s edition of Adlard Coles's magnum opus. He mentions oil, either seeping from bags or pumped out through the heads, and says he used to carry oil bags but never used them. The oil was some kind of "heavy fish oil" apparently, which is admirably green though I'm sure they didn't give a toss in those days.
His conclusion overall was that oil wasn't useful in the sort of quantities that a yacht could sensibly manage. He reckoned it would need a substantial ship to rig a spray from its fuel bunkers to have any effect worth the effort. And messing about with oil on a small boat was likely to just make the decks slippery and hence more dangerous.
Fantasie 19
23 Mar 2009
Chichester, West Sussex
Just finished reading "The Golden Keel" (fiction I'm afraid) but Mr Bagley uses that ploy when his hero's boat is caught in a severe storm.... the book was written in '63, so clearly the idea was prevalent then....
bedouin
It is a long time since I read it but I think the Pardeys' book on heavy weather sailing suggests this method. As far as I can tell it can only really work if you are hove too and drifting slowly down-wave so that you stay in the lea of your oil slick
prv
29 Nov 2009
Southampton
The Pardeys use the word "slick", but I don't think they mean oil. Just the flattened water left behind a long-keeled boat moving slowly sideways.
caiman
17 Mar 2010
52 43N 004 03W. ish.
Whale oil was used as 'wave subdueing' oil on double ended Lifeboats such as the Chieftain as mentioned above.Sprayed either side of the boat from a dedicated tank/ pump.Certainly fitted as standard on double enders in 1982,but gone by 1992 in the transom stern Lifeboats.
I have tried it when attempting to pull a boat off some rocks in our Harbour.I used diesel.It worked for me..
Cheers
trapezeartist
4 Sep 2009
Portishead
www.littlehotels.co.uk
It's probably quite difficult to get hold of whale oil unless you're Norwegian or Japanese. Whatever other issues there may be, at least it would be reasonably environmental. I hope no-one would try it with an old sumpful of Duckhams :disgust:.
caiman
17 Mar 2010
I think the ethics and availability of whale oil was the reason that the RNLI ceased using it.As far as using Duckhams,'needs must when the devil drives'.As stated above,diesel worked for me.
Cheers
Seajet
23 Sep 2010
West Sussex / Hants
There was also the theory of pumping oil out via a sea toilet, though I think the risk of the slippery mess, the quantities required and the environmental considerations make it a non starter these days.
When I was at photo college in 1980 we had to go and photograph the coaster ' Athena B ' which had piled up on Brighton beach in a storm; there were oil cans hanging from her stern - don't know how much effect they had, but all the crew got off safely.
RAI
13 Jun 2006
Ayamonte
Oil on troubled waters. I wonder how far a litre of WD40 would go? (It's fish oil) Would olive oil work and be environmentally forgiveable? I think it's supposed to stop waves up wind of the boat from breaking.
