tom52
My Volvo 2020 has developed a small but annoying oil leak.
The leak is from the seam where the sump is bolted to the bottom of the engine.
The flat mating edges of sump and engine are bolted together with small nuts and bolts about 40mm apart. There are dozens of them and some are difficult to access. Presumably there is a gasket between the mating edges.
I am reluctant to attempt removal to replace the gasket.
Is there any sealant or liquid gasket that can be 'grouted' into the seam that would stop the leak ?
