Oil for Perkins 4108
CalicoJack
5 Jan 2004
Chatham, Kent
I went into Halfords today and they had two mineral oils for older engines, both their own make. One was a 15/40 oil with an API index of CD & the other was 20/50 with an index of CC. Previously I have used a mineral 15/40 CF mineral oil.
Any thoughts on which would be better? Oil consumption between changes is virtually nil and the oil is changed twice a year.
CalicoJack
5 Jan 2004
Chatham, Kent
Twice a year?
1). Boat engines even those with an indirect cooling system run cooler than cars.
2). It doesn't run hard enough or long enough much of the time.
3). It's cheap enough.
robmcg
17 Sep 2006
In exile in Scotland
Sounds like the head needs a decoke. Leave it to the off season and get amongst it then. :encouragement:
Oops! Answer should be on the other Perkins thread! :sleeping:
vyv_cox
France, sailing Aegean Sea.
coxeng.co.uk
The 20W-50 oil would typically be used in engines with high oil consumption in order that the higher viscosity will reduce the flow past the rings to some extent. It will also help to cushion shock loadings on worn bigend bearings. In your case it would seem unnecessary and I would go with the 15W-40, which is probably the oil specified by the engine maker.
AndrewB
7 Jun 2001
Dover/Corfu
The original oil specified by Perkins for the 4-108 is 30 monograde, API CC. This is technically obsolete but still available for old-fashioned motor mowers though not easy to find and expensive. I've been using 15W-40, API CF4 for many years now. This engine is pretty tolerant, but I prefer to stick to mineral oils intended for older diesel engines, not modern synthetic oils.
P.S. There are later grades of oil that will substitute for CF4, but always it will say so somewhere on the can, so if you can't find CF4, check the small print.
brianhumber
30 May 2001
Sussex
Firms like Morris supply oil for older engines and supply in 5 gal (ok 25 litre now) containers.
As an aside there is no need or benefit in changing your oil every year if it still meets the specification in spite of the b...sh..e written about this every year. Oils, fuels, and engines have changed for the better significantly since the decokes needed on 50 and 60s engines in which era the authors of engine articles in sailing magazines etc still seem to be stuck in.
Brian
westernman
23 Sep 2008
Costa Brava
www.devalk.nl
Brian
http://gulfcoastfilters.com/1,000,000 MILES.htm
TQA
20 Feb 2005
Carribbean currently Grenada
sailingonelephantschild.blogspot.com
Brian
I disagree. It is important to change every year as boat diesels run cool and you get an acidic build up. Change before winter storage. If you are pinching pennies you can change the filter every second time.
However I am a tight Scots git and change the filter every time I change the oil. Cheaper than a rebuild or new engine.
vyv_cox
coxeng.co.uk
Fully agree with all of it (except the tight Scots git part of course). Marine engines rust out, not wear out.
Heckler
24 Feb 2003
Vyv
I noticed in Wilko in HH that they are selling 20/50 for classic engines £16 and a 20/50 more modern multigrade for £12 Prob is that they dont put a rating on the bottle. http://www.wilko.com/car-care/car-m...ngine+Oil+and+Coolant&setpagenum=2&perpage=12
Stu
sailorman
21 May 2003
Here or thertemp ashore
Vyv
Stu
Mineral based classic car oil. Quality mineral oil, specially blended for cars from the 1960s, 70s and 80s. Contains calcium long chain alkaryl sulphonate. May produce an allergic reaction. Specifications API, SE, CC. Keep out of reach of children. Always read instructions.
TonyBuckley
15 May 2006
Boat is in Brighton Marina
www.icloud.com
when I asked Morris's about my engine - 30 year old Lister - they recommended this.
http://www.morrislubricantsonline.co.uk/golden-film-marine-10w-40-engine-oil-api-cc-sf.html
But of course see what your engine manual recommends. My engine doesn't seem to use any oil and its being changed next week I hope.
vyv_cox
coxeng.co.uk
I use a similar oil from Morris in the BMC 2.2 in Cecilia, although I prefer the 15W-40 version. Seems to be a most appropriate oil for these elderly engines. Morris seem to have almost cornered the canal boat market, where such engines are common.
