O-ring replacement - size advice
gregcope
21 Aug 2004
Hi All,
I want to replace an old O-ring.
The ID of its slot is 15mm. It is 2.5mm Dia. Which suggests and OD of 20mm. However the ID of the whole it fits is 19mm.
What size OD O-ring to get?
Plum
6 Jun 2001
UK East Coast
Hi All,
allowing for 25% compression is OK for a static seal but for a sliding seal 20% max or rotating 10% is what i would plan for
Plum
6 Jun 2001
UK East Coast
This is a sliding seal. So 20% of 19mm is 22.8mm.
I was thinking 20mm OD - 15mm ID/2.5mm Dia.
If the id of the shaft groove is 15mm and the id of the bore the o ring slides in is 19mm then an o ring with a 2.4mm diameter cross section would be compressed by 20%ish on assembly.
B27
26 Jul 2023
It's 20% of the cross section, so a 2.5mm strip of rubber is compressed to 2mm.
It can make a difference if the width of the slot is tight, your round section o ring becomes square section...
If 15 ID x 2.5 xs is too tight, you could try a smaller ID so it's stretched , thinning the section a little.
