Noisy Echaust
wiggy
13 Jun 2001
Portsmouth Harbour
How can I solve my noisy exhaust problem. I ahve a Yanmar 1GM10 that goes through a small waterlock then about 2m exhaust before exiting over the side. In the cockpit it is noisy andf I would like to solve this problem.
steve28
19 May 2003
Cornwall
www.falmouthgypsy.com
two options for the exhaust, first is to change the waterlock for a better type, i assume you have an in line lp40 which is a bumpy external contours.
second is to fit a muffler in the line as well.
have a look at www.halyard.co.uk, they make a much better design of silencer which cuts the noise down to around 40% less. This is purley down to the design and materials they use.
I dont work for them, just have used their products on so many occasions and very happy.
I actaully have a water lock and then a water separator which splits the water and exhaust gas and puts them out in two places, this makes the exhause output nice and quiet .
steve
jerryat
20 Mar 2004
Nr Plymouth
Hi Wiggy!
I'd go for the Vetus waterlock and then their muffler. Both reasonably priced and extremely effective. We reckoned the above combination cut the exhaust noise by at least 2/3 when we installed them on our Fulmar.
Hope this helps!
maxi
8 Nov 2002
Hampshire
Just to confuse you, it's entirely possible to have noisy exhuast hose. I changed the hose recently on my perfectly acceptable exhaust, only to find that the new stuff had a horrendous echo, reverted to the old but knackered hose and all was well. Good luck.
