VicS
Screwdriver the starter to see if it turns over
Meaning do what precisely?
Has the wire come off the back of the ign switch? Is there a relay in the circuit? Start at the switch & work your way back to the battery & I'll bet you'll find a break somewhere.
I heard that switching the key off while the engine is running would blow the alternator.
And me.
By pass the ignition circuit and system by using (a well insulated) screw driver to short across to the starter moter from the power supply.
Can't say I've ever done on a boat. got my car going a few time though.
Get you home bodge not recommended as routine. usually blows lumps out of screwdriver.
By pass the ignition circuit and system by using (a well insulated) screw driver to short across the solenoid to the starter moter from the power supply.
Look along the high tension wires from batteries
one side is to ground. The other goes from battery to solenoid then from other side of solenoid to starter moter.
Not familiar with OPs motor. some more modern starter moters have solenoid attached as single unit.
It can also be done using a jumper cable direct from battery to the starter.
Take a wire (or a screwdriver) from the power in cable to the solenoid feed tab (big fat one that comes from the battery and apply it to the solenoid spade connector tab). It doesn't have the explosive effect of shorting out the power terminals, but activates the starter the way it is meant to.By pass the ignition circuit and system by using (a well insulated) screw driver to short across the solenoid to the starter moter from the power supply.
It can also be done using a jumper cabledirect from battery to the starter.
But avoid actually starting the engine because with no power on the panel the stop circuit will be inoperative
It won't start without the stop solenoid being energised, it defaults to off
... I have just discovered that there is no power to the starter connection from the battery (via battery switch) ....
You could run a new cable just to check but are you sure the fault is on the positive side not the negative side.
