dgadee
In front of the house, buoys were installed which flashed in time with each other - noted on charts. Not any more. Any idea why Irish lights might have changed the sequence?
Are you sure they flash? because where my mate Paddy lives they are fixed.
But he gets a lot of lorries drive past his front window & he gets confused![]()
Mick has had a row wid Murphy & refuses to flash his torch at the same time
Just being "bloody minded Irish"
it probably works OK if the channel is dead straight but with slight bends you could find yourself wondering which buoy you were actually looking at.
It was pretty weird to see
As well as shore lights and some fixed lights there were lights at the base and ends of the moles. Some of these were flashing and some occulting, which was bad enough, but several had different coloured sectors, so that a light that appeared to be flashing red would change to flashing white and effectively disappear, or the reverse. The odd fishing boat coming and going didn't help either.
As do the yellow lights on the sets of beacons outside and inside Pompy Harbour which aid the new carriers arrival and departure ( they do turn sector lights on when the vessels are actually transiting in or out).Wind farms flash simultaneously.
Now you mention it, the experiments in the Swale did include a period where the lights flashed in turn leading along the channel and that did seem to work for me.I have seen them in action, but I can't remember where. (Not Swale, but I thought it was somewhere East Coast-ish?)
I think, to the contrary, sequentially synchronised lights are actually most valuable when the channel is not straight, at least from the point of view of a vessel following (or navigating in relation to) the channel. In that case it is more important to know it is within the channel (or outside of the channel in some cases), and where it is turning next, than where along the channel it is.
It is less handy for those trying to establish exactly where they are.
I can remember approaching Plymouth at night years ago (i.e. I had no GPS), exhausted and sleep deprived after an eventful single-handed trip to the Scilly Isles. As I entered the Sound I was confronted with a vast sweep of dozens and dozens of flashing reds, greens and whites, and struggling to work out which were small buoys close or large buoys more distant. to try to discern which was the big ship channel I wanted to avoid and the smaller passage (the Bridge) further in that I needed to find. Synchronised lights on the big channel would have greatly helped me (and the big boys) perceive the general layout.
I can imagine it could be very helpful if the big channels through the sands of the Thames Estuary were sequentially synchronised. Currently (or at least before the wind farms were installed), unless you know exactly where you are, is that nearby buoy the next step along your current channel, or just the other side of a deadly shoal?
When I encountered some of these sequentially synchronised lights it was decidedly un-wierd. It made the place seem like some sort of suburban road network, rather loosing the mysterious, seemingly random twinkling of a conventional arrangement, where the pattern of the layout can only be divined by those with the requisite arcane knowledge.
Think it's probably like radars when you have two. They turn at the same speed but get out of sync after a while.
W.
I was told at the time that they all run on GPS clock.I think not. I believe they're synchronised by radio signal or similar.
