stuartgsd14
Of to have a look at one of these for sale tommorow any tips on what weak points to look out for....
help appreciated..
help appreciated..
help appreciated..
Nathan of these forums has been living on one for about 3 years. He is a tad younger though, and has now treated himself to a bigger boat.this will seem cramped
After a search on the forum it seems that build quality can vary ,have read that ballast depends on what was lying around at the time
Corribee and coromandel seem to share the same hull with topsides adapted to take advantage of the junk rig on the latter.
Have been looking at bigger yachts so expect to find this will seem cramped but i do like the idea of the junk rig as a novice and elderly newcomer to sailing it might be just the ticket.I would think as a trailer sailor it would be ideal as easy to rig i assume?
Beware the 'trailer sailer' idea.
I have a lift keel Anderson 22, and launching / recovering is a reasonably major task at this size; get a mooring, a half tide one on mud is actually preferable in my view as it's usually much closer inshore, and access by tender is very often tidally limited anyway.
Trailing the boat home for the winter, or maybe relocating for a summer cruise may be on but as for trailing, requiring a machine gun to get access on & off a busy slipway, launching & rigging, de-rigging then back onto trailer for every weekend, unless you're really curious as to what a heart attack feels like, forget it !
The junk rig is not to my personal taste, but each to their own; one Anderson was junk rigged, as the buyer was a friend of Blondie Hasler, a name which will ring bells with any junk devotee.
This boat was immediately converted back to standard bermuda rig by her next owner.
Also check out the mast step and any raising / lowering arrangements, I can't remember the Coromandel set-up but a lot of junk rigs use a flexible mast stepped on the keel, through the coachroof; this would be a big and usually very expensive exercise to step & unstep frequently, requiring a crane or hoist.
???? Can it be free-standing and on a "hinge"?If your free standing mast is on a hinge then raising and lowering could not be easier
I have the opportunity to purchase a folding mast (I believe made by needlespar, but not 100% sure)
I understand that the substantial hinge is made from stainless, with a stainless sleeve that slides down to keep the mast in position.
Wont it just fall down?
I owned a Coromandel some years ago.
I thought the cabin worked well, though the separate heads is, of course, rather tight.
The rig has lots of good things: simplicity and repairability spring first to mind.
However, we sold after a year, as I found the rig so simple that I got bored. Tacking required only putting the helm over, gybing was usually relatively gentle. You could rightly say these are big advantages, but it just took away lots of the 'feel' and satisfaction of sailing.
From photo's the Coromandel would appear to have a gaiter and through-deck mast; doesn't seem a simple idea for chucking up the rig on the slipway to me.
