New teak, what would you expect to pay?
Carmel2
1 Jan 2005
The possibilities are endless.
We have 15 year old teak seats in our cockpit, it's getting a bit thin and most of the caulking is soft. In total it's about 2.5sq meters over 11 panels. So my question is what would you expect to pay to have it stripped out and replaced inc labour and materials?
ip485
13 Feb 2013
I think that could be a how long is a piece of string question because;
- the labout element will depend on how easy it is to remove the teak (how is it bonded etc),
- how thick and what quality replacement teak is used,
- how much cutting etc is required.
I suspect you could get a good idea of the cost of the materials from Robbins one of the few suppliers of really good teak.
and if you want to save on cost I find some very good quality teak can be sourced on eBay.
Tranona
10 Nov 2007
Best approach is to get pre made panels and glue them down. Removing the old is not a skilled job, but can be hard work and tedious.
To give you an idea panels from Howells in Poole are around £260 per sqm. However a minimum charge per panel applies so you 11 panels will likely work out more than that. You can get a quote from www.kjhowells.com. If you fancy complete DIY they can supply the teak to either lay direct or make your own panels.
Tranona
10 Nov 2007
It could be either solid teak which will be 4-6mm thick or teak strips bonded to a ply substrate. 6mm would be common replacement for cockpits, although 9mm is also possible.
vyv_cox
France, sailing Aegean Sea.
coxeng.co.uk
A few years ago I heard of several owners who were having teak decks relaid in Turkey, which was then the cheapest place. The word is that Turkey is more expensive now but there still might be a bargain to be found.
aussi
1 Sep 2005
Shropshire, boat in Conwy
www.eboatcards.com
I'm not too sure where you're based Paul, but you could give Barry at TLC a call - He's really friendly and helpful and I'm sure would be happy to give you an idea of costs. Some photos would no doubt help!
bateau57
3 Feb 2009
It is possible to get a good job done in Turkey but as vyv_cox says it is expensive. The going rate is currently €600 per sq metre. That is deck prepared, primed, 9mm thick teak (imported from Asia and cut from logs locally), SikaFlex applied properly (primed, glued, gaps primed and corked) then sanded. I did my own because I have the skills and the tools necessary and did some extra deck joinery to match etc. When I say it is a good job I do know what I am talking about and the best guy I know is in Finike Marina. I would not get anything else done there but the carpenter is good at decks. You can get it done at other places but this guy does a supper good job. I have monitored friends jobs he has done over a period 7 years.
macd
25 Jan 2004
Bricks & mortar: Italy. Boat: Aegean
...the best guy I know is in Finike Marina.
Could you clarify which 'guy' you mean, bateau? One of the yard chippies does decks, plus there's another contractor who comes in from outside. I've seen both do decks, and do good work (to my untrained eye). They seem to share the same deck weights (chunks of old railway track). The yard guy's quite cheerful, the outside guy a bit of a grump by reputation, although evidently the results are worth it.
