ThreeSummers
I recently changed the prop on my 60hp outboard from three blade 17" to four blade 15" pitch. Looking at the new one, I noticed that the trailing edge of the blade is squared off and that edge is around 4mm thick at the widest point. It starts at the base in line with the keel, and ends near the tip near 90º to the blade - am I making sense? The old prop's trailing edge is not square.
Three things - does the square edge create drag on the prop? I imagine at high speed that water wont be able to flow around that "corner" quick enough - possibly leading to cavitation?
Two: it vibrates more than the three-blade - I'm lead to believe it should be smoother - also from the square edge, or maybe unbalanced?
Three: if I shut the throttle quickly, as the motor passes through around 3000 rpm (+/- 1100rpm at the prop) there is a shrieking noise for a second or so as it slows down - is this a 'singing prop'? This makes me think I need to grind that edge off - maybe it will get rid of the noise as well as the vibration, but I'm not willing to do without some advice or other's experience of similar behaviour?
Any thought?
Regards,
Tim.
Any thought?
Regards,
Tim.
