Mr Googler
pitting doesn t look to be at the bottom but somewhere on the side, right? in the pic above you are holding it 180deg rotated, right? I agree pink is superficial.
Can you somehow remove the seal from there before attempting removing the core? that's what I did on mine but construction on the IVECOs is much more user friendly. Is the other endcap off as well? If so, you know, flat piece (pref round and just fitting in) block of wood on it, hammer, it will givein. Obvs no idea if there are special tricks to get them off on a volvo...
yes…..you can see the “tide mark” so the photo is upside down. The core is pink coz it’s been rydlymed
Seal will come out then tap it through is the method ?
I just don’t know if it’s worth bothering with. took 20 years and it’s not even half way to the seal.
