scottnewcombe
I've just replaced the transom on the old wooden tub. Now to bolt all the bits back together.
So here's the thing. The old exhaust set up was exhaust manifold-water injection point(below water line)-1m length of exhaust hose (50mm)-2m length of yellow(gas?)plastic pipe- straight out the back under the water line.
Now I know enough to a bit worried to say the least about the old set up. Plastic gas pipe eh??
So.. I was thinking water lock and swan neck and exiting above the waterline.
However there is only about 350mm between the waterline and the deck level. This is not enough to get a normal type swan neck in at the transom.
So my questions are
1. exhaust outlet above or below w/l. (would like to see water pumping)
2. alternatives to swan necks.
3. any other bright ideas??
TIA
Scott
2.5BMC deisel 27' wooden MB
So my questions are
TIA
Scott
