jamie N
Never mentioned it at all.and dismissed the hole in the hull , or did he venture a " reason " for its being ?
Or understanding what happened, in order that it doesn't happen again?what about apportioning blame ??
I would think if it was flooding from inside then the ramp / door would have had to have. been damaged / breached before the main “ visor “ door to be burst allowing it to be torn off by the storm / waves ,,, 4 X 3 , mtr or ft ?Let’s be clear that this was a disaster on the scale of the “Titanic”. These ferries are an everyday part of life in the Baltic. Everyone uses them, if only to go on a booze cruise to Mariehamn. Now and again one scrapes a rock or runs aground, but people don’t die. Except that suddenly 853 people did.
The “Estonia” did not have clamshell doors like the “Herald of Free Enterprise” did. She had an outer door which pivoted on two hinges at the upper corners and lifted like a helmet visor. Inside this the ramp itself formed an inner door.
The visor was found separated from the rest of the ship, and was recovered. The hinges were broken as was the locking mechanism. The ramp was not able to act as an inner door on its own and that failed too.
In a roro ferry the car deck is the weather deck. The water cannot run off easily because of the ship’s sides, so extra large scuppers are provided but they can still be overwhelmed. A four by three hole would not overwhelm the scuppers; a failure of the doors will.
Or to find out what happened and stop it happening again?There can only be one purpose in raising these questions at this late stage...........to make money out of misfortune.
I'm not clear how a ship like this with overwhelmed scuppers takes an hour to sink?Let’s be clear that this was a disaster on the scale of the “Titanic”. These ferries are an everyday part of life in the Baltic. Everyone uses them, if only to go on a booze cruise to Mariehamn. Now and again one scrapes a rock or runs aground, but people don’t die. Except that suddenly 853 people did.
The visor was found separated from the rest of the ship, and was recovered. The hinges were broken as was the locking mechanism. The ramp was not able to act as an inner door on its own, not least because the failure of the visor dragged it open, and that failed too.
The similar but smaller scale sinking of the Princess Victoria (133 lives lost) in 1953 is still an open wound in both Stranraer and Larne, even though it's a very long time ago. Every time people from both ends see ferries leave or arrice, they remember.Let’s be clear that this was a disaster on the scale of the “Titanic”. These ferries are an everyday part of life in the Baltic. Everyone uses them, if only to go on a booze cruise to Mariehamn. Now and again one scrapes a rock or runs aground, but people don’t die. Except that suddenly 853 people did.
Downflooding through ventilators took its time. Final report https://lounaeestlane.ee/wp-content...udy_on_the_Sinking_Sequence_of_MV_Estonia.pdfI'm not clear how a ship like this with overwhelmed scuppers takes an hour to sink?
The modelling done as part of the investigation linked at #29 and 30 is fascinating and presents a sound explanation for the sinking and timeframes. Interestingly it does call for further dives/ROV work to re-examine the hull, although I suspect more from desire for completing the work at hand than because of any failings in methodology.
Take an average plastic basin put an inch of water in the bottom and carry it with you while you go for a walk.I'm not clear how a ship like this with overwhelmed scuppers takes an hour to sink?
I've capsized enoug dinghies to be familiar with the effect of free water aboard.Take an average plastic basin put an inch of water in the bottom and carry it with you while you go for a walk.
you will expierience on a small scale the “free Surface effect”
instead of a basin a wide open car deck. It only takes a few inches of water.
1 cubic meter of water = 1 t.
100 sq m of water 1 cm deep = 1 t
doesn’t take a lot.
