New drilled wooden block for Plastimo Standard Outboard Bracket
NorthRising
30 Mar 2009
North - Sonata
Does anyone know where I can obtain a drilled replacement wooden block for this type of bracket - they don't seem to be sold separately (no suprise there).
http://www.plastimo.com/catalogue/productdetail.php?LangID=1&ref=17619
To make one I'd need to drill two 8mm diameter 270mm long holes through the block to take the threaded rods on which the wooden pad is suspended; unfortuntely that is beyond the abilities of both me and my toolkit.
rob2
23 Aug 2005
Hampshire UK
I know it's mot what you want to hear, but I suspect that you won't find one off the shelf. Faced with the same problem I would laminate a replacement, routing grooves in each half to make the hole when assembled.
Rob.
Giblets
5 Mar 2006
Surrey
Perhaps Chuchilo of this parish may be able to help. He is good with wood and has a lot of very impressive wood working tools in his workshop.:)
VicS
13 Jul 2002
Braze a drill bit onto a length of steel rod.
Drill half way from each end.
Care, or a guide, will be needed to keep going straight. But easy if you can fit the drill in a lathe.
Withdraw the drill frequently to clear the swarf.
pvb
UK East Coast
I'd also drill from each end. But I would bother brazing a rod on to a standard drill bit, I'd just get a long drill bit. One around 150mm long would do the trick; they're only a few quid.
prv
29 Nov 2009
Southampton
Looking at the bracket in the picture, is it really necessary to bolt right through? I'd have thought a pair of chunky coach screws at each end would hold it firmly enough.
NorthRising
30 Mar 2009
North - Sonata
Right here is how I solved this one:
- The old block was 36mm thick so cut two pieces of 18mm ply to match the width and height of the old block.
- Epoxy bonded these together
- Epoxy bonded three strips of glass tape around the thing just in case the bond fails (don't see why it should - more a just in case)
- Sanded, and a few coats of varnish
- Extra length drill bit from tool station, placed block into bracket and drilled in from both sides, using the holes in the bracket as a guide, until they met from each side, this was the hardest bit.
- it all goes together well and feels robust.
VicS
13 Jul 2002
I expect in the 2 years since he asked the question the OP has found a solution
M
Mark Turner
Sounds about right, I've got jobs that have been hanging around about that long...:D
Indeed, an inability to get through my winter lay-up list of jobs to do has lead me to a philosophy that its not that a job is taking too long to do, just that it went on the list too soon. For example, in 2007 I decided to start replacing the headlining on my Gibsea, and got the forecabin done straight away. This year I'm tackling the aft cabin because the headling actually fell off in some places last year. Cant help thinking that the forecabin was done in haste:)
NorthRising
30 Mar 2009
North - Sonata
Yeah I made do with the old block for a while longer than intended, but the split in the old block was never going to get any smaller; amazing what productivity the windy not very warm weather can induce.... sanded and re-varnished the tiller too.
