The previous set up was nylon pvc tube with a compression olive. So no barbs. I'd like to install a proper fire-resistant hose hence the need for barbs.Agreed. When replacing it would seem easy cut out a bit (away from the end to avoid the expansion) for measuring.
Same with barbs (if they need replacing?).
That type will need a washer Roger and rely on making a seal on the face of the housing.Tis is the type of fitting you could use
CAV Lucas Delphi filter pipe adapter 1/2" UNF to 8mm - Diesel Injection Pumps
For £45quid you could replace it with a racor knock off. I even added a fuel tap to make changing the filter a simple easy job.While you are at it, why not make your life easier and fit a spin on filter conversion ?
For instance: Spin On Fuel Filter Conversion Kit (CAV Replacement)
The Racor copies are now at silly prices, £16.15 !!!
500FG/FH Diesel Marine Trucks Fuel Filter Oil Water Separator & Bolt Ring UK | eBay
Me too.I fitted one of these to help prevent sediment blocking my primary CAV filter
The thing is, after 4 years, I've finally mastered changing my CAV filters... Feel strangely bonded to the b@gger.
No they're not. They are a bloomin' abomination.Yes, they're quite OK with a bit of practice
Try balancing that pile of jenger at 3am underway in choppy water without regurgitating your dinner.
For under 20quid changing to the drop in type is a no brainer.
Do it now. You'll thank me one day, sure you will, you will, you will...
A Facor/Racor-a-like is not that much bigger than a cav. Could you fit it outside the engine bay in an easier to access location?I actually largely agree with you, and have said much the same as you, though with far stronger language, when I have been wrestling with the blessed things in boats. (Maybe I should have added calm seas and plenty of time and patience to my list of caveats?) They are probably alright on trucks and tractors.
I have actually already bought a Chinese drop-in Racor type as a replacement for my boat's CAV which lacks the benefit of any of my above stated conditions, but am beginning to doubt that I actually have sufficient space for the Racor-alike in my engine compartment. Hence I was pondering earlier in this thread whether a swop to a screw on type (or better still, two with a changeover tap), and if so whether I would then also need a water separator.
<pedant mode>Yes, they're quite OK with a bit of practice, but only if you've got -
decent frontal access at a convenient height;
space and/or surfaces underneath that facilitate catching/cleaning up after the inevitable diesel spillage; and
the replacement filters that you bought come (as they rarely do) with all three replacement seals.
