New Boat - Squadron 58 - Almost
jrudge
4 Dec 2005
Live London, boat Mallorca
So I almost have a new boat.
She ( it ) is a 2004 Squadron 58 - square porthole facelift model. Went to see it yesterday and took it on a sea trail and all is mostly well.
At this age they are have 2 things in common unless someone has done the work - the teak is pretty much shot and the interior linings ( cabin walls and ceilings) are mostly sagging / coming away. I am not sure if this is failure of the foam or the adhesive. Similar issue with car headlining are put down to the foam, so this seems the mostly likely reason.
So... the teak is shot! The caulking is significantly proud of the deck and in a few places there is no teak left. It is heavily ridged ( I do wonder if it was regularly pressure washed?) and need replacement. The cost of the teak from Watsons inc VAT is £13k + the labour to get it off and on again.
As the season is upon us I propose a trim the chalking and light sand job. This has been discussed on a few threads such as this one
http://forums.ybw.com/forums/showthread.php?456103-Sanding-teak&highlight=
This wont solve the issue, but for what I assume is a few days work will make it nicer under foot and to look at until It all comes off. Forum teak removal party anyone ? Maybe 500 beers to weigh it down that can be drunk once the adhesive is dry!
The side decks are actually some £4500 of that total, and in an ideal world I would just remove them and have no teak, but I rather suspect the odds of total removal of the adhesive is almost nil. I have seen the MAPISM thread, and I dont really want to cover the deck with another finish. It is possible I suppose that the correct solvent and elbow grease would get it off - any comments?
The cabin linings are also pretty bad. I cant find anything directly on line about dealing with this, but there are plenty of car posts about failing headlining where people have tried to inject glue etc to re stick it, but the guidance there is pretty clear that it does not work, and stains the fabric.
Taking some of the panels off is simple ( ceiling) some seem less so - mostly the cabin walls. Anyone who has done it then advise welcome. Recovering should be simple ( I have done it before) with the right materials and spray glue, so it gives the chance of a moderate interior update.
The anchor chain is visibly rusty - I dont know what new chain costs yet but I suspect that replacement is more viable that trying to find someone to clean and hot dip, but again all guidance welcomed!
The survey covers a few more things, but nothing drastic. Cutlass bearings to be done in the next year and very minor week in one shaft seal.
A few things came out of the idea trial.
EVC - the EVC was flashing. This was not a code ( as in 2 flashes followed by 3) but depending on your interpretation either 13 flashes followed by a very small gap, or continuous flashing. I cleared it once and it came back. Cleared it again and then it was off for the duration. Any ideas? I have asked for a Vodia tool to be put on the boat to see if there are issues.
The steering on the top helm was no good. Many turns at slow speed to make it do anything, at speed it was below average but worked. I gather the steering is in some way pressurised and may need "pumping up" or alternatively there is lack of fluid / leak. The lower helm and auto helm are all fine.
The vacuflush sounds like there is a train passing through the boat so using that at night without a fix is a no no. How loud is it supposed to be?
The entire 12v system dropped out half way through the trail which I gather is a dropper likely to have failed.
One AC unit comes on at the controller but does not work. It is just an air handler, and the fault could range from simple to a new motor.
And finally there are rust / leak marks under an elbow in the stbd exhaust.
All the sea trail stuff is back to the vendor and we will discuss the plan ( fix or pay) today.
Other than the its a decent boat with a complete service history that seems to have been looked after. Time will of course tell!
Forum wisdom on the above appreciated.
Jeremy, I'm glad you've found a decent boat instead of that junk you were looking at before :).
Regarding headlining, if it's worse on some panels than others then why not fix the worst ones first? If you speak to Fairline you can get the fabric name from the build sheet and as you've seen, they have loads of rolls of old fabric in their warehouse so you might get lucky and find they have some in stock.
I would suggest a call to Ed Engel, ex Fairline trimmer, excellent craftsman who can replaced carpets on my various boats and I believe replaced the linings on the Fairline Squadron moored next to me - Drumbeat.
Number 07860 192119
It sounds that you have found a good boat and best of luck getting it over the line
-Andrew
+1 for Ed, although he has been talking about slowing down or even retiring, definitely worth having a chat with him.
Number 07860 192119
-Andrew
Great news Jeremy, and you seem to have a very thorough understanding of the issues you need to fix. The headlining segments on my Azi are Velcro fixed. Not sure about your Fairline OE, but could you use Velcro in lieu of glue? Will this refix some of your problems, or are they too far gone?
Teak you know all about, but what about lino teak for the side decks and fly, rather than the real thing, which will require constant maintenance? Of course the real think in the cockpit, but this is easier to maintain as it is shaded when you are not on board.
Well done on the new boat J. If it is in Cala D'Or then I am up for the party!
Well mine sound like a bomb going off and then a train passing through a station as the vacuum pump kicks in. Night time toilet use and an undisturbed night for everyone else on board are pretty much incompatible.
Congratulations J. Any pics? Is she in the Med?
Any major yard will have an upholsterer that will do that kind of work. The problem may be that if you need to replace the lining material, you may not be able to get an exact match and even if you can, what is there already may have faded so any new material will look different.
If it really bothers you, chuck it away and buy some new chain. In the grand scheme of boating costs it will be pennies
They do so either live with it or replace them with some nice new Tecma units
Is this a chilled water unit with remote compressor? If so and the compressor is working then it could be the air handler motor which shouldnt be too expensive (again in the grand scheme of boating costs) but the first thing to do would be to swap the controller over with another one that you know works to check that it isnt the controller itself which is at fault. But this should be the seller's problem to sort out not yours
That you really do need to sort because you dont want something drastic like an engine stopping or your nav instruments going blank whilst you at sea but again this is the seller's responsibility to sort out
As a general rule play hardball with the seller now with regard to getting all and any technical problems sorted out because, stating the obvious, once you hand over the balance of the monies all the technical problems are yours
Very nice - the one we discussed?
What you say makes sense. If you could remove the teak there is moulded no slip underneath but the labour of getting it right will be more than the new teal. Best just to buy new from wattsons and just solve the whole thing with £££
Ceilings easy. Walls are way more complex. I know how to remove the 4 lots of cabinets under the side windows in cabins but is a complex job and I'll explain in person sometime - hard to describe here. You have to do this, to replace the wall fabric that those cabinets butt up against. Separately, the walls as you enter either side of master cabin are a big job. you have to remove carpet to get bottom of wall fabric, and you have to remove ceiling and lattice frame work for ceiling to get at top of fabric. Can be done, but big. Matching fabric might not be aviaalble - I have no idea. But current fabric easy to obtain from OEM source (I give you the contact - it is a maharan New York fabric, but there is an importer in North London whose email I have back in office), and surely you want to upgrade to current wall fabrics. I have a new full roll of the Tekwall beige used by FL OEM in squadrons and targas in the last few years, and you can have it foc if helpful
New chain. 10mm
From those symptoms, almost certain needs fluid (under rubber cap at top helm) then a bike pump pressurisation in engine room starboard side wall. Easy
Work of the devil. We just ripped out 4 from my brothers boat and put Tecma in. On sq58, the plinth is big enough that Tecma (which has a big foot) drops straight in. So buy 2x Tecma and be done with it. you have to make a little but of wood work at back of tecmas on sq58 due to the release angle on the bathroom wall moulding but this is easy to do. Pete Bell did mine!
Fit new a/handler. £1500
You MUST buy new elbows or get them knocked off price. They do and will fail. not great work by Halyard, but easily replaceable by Halyard and will last 5 years. Not cheap, like £1500 each. Knock off the price. these are a standard "fail" item on sq58
Great news Jeremy!
The sq58 doesn't have a 12v "system" in the sense of 12v battery and 12v chargers like sq78. It just uses droppers from 24v; easy to change victron items I think. Located under lower helm, reached thru starboard cabin ceiling which is held on by 3M dual lock. Also some of this hardware is reached thru back panel of stbd cabin wardrobe, again 3M dual lock-ed on. and the droppers might be under the port side switch panel, reached thru the port cabin ceiling. You need to buy yourself a short ali step ladder :) If you need info on wiring layout/architecture just ask - I'll remember quite a lot of it
Congratulations, J.
The Sq58 was, and imho in many ways still is, one of the best boats in the 55' to 60' segment.
I could as well have bought one, if it weren't that the very few I came across with the powerplant I liked (Cat 3406) had silly asking prices.
Mind, not that there's anything wrong with the VP engines that as I understand you have in yours.
I was just sticking to a promise I made myself many years ago to not buy any green engines again, but that's a personal thing! :rolleyes:
WIth regard to your comment ref. teak replacement...
...I can perfectly see what you mean, but have you ever seen in flesh one KiwiGrip deck?
Trust me, it's on par if not better than the moulded diamonds pattern.
Otoh, if you like the teak feeling, who am I to argue?
Just keep into account that rebuilding the teak means falling again in the very same problem after X years.
Which might be a problem or not depending on how long you are thinking to keep the boat.
For me, after keeping the last one for 16 years, and hoping that the new one will last even longer, rebuilding teak was simply not an option.
In fact, NOT having teak on decks was a pretty high priority in my personal list of "ideal boat features".
I ended buying a boat with teak just because that was standard on all DPs, which both myself and swmbo liked in most other respects.
Compromises, as always... :)
Congratulations jrudge, hope the purchase goes through smoothly.
I think B E Wedge in Willenhall is the only UK co. that can re-galvanize chain http://www.wedge-galv.co.uk/plant-locator/b-e-wedge-ltd/. I doubt it's worth it though, by the time you've shipped it there and back, although the galv may last a lot longer than some cheap new Chinese chain.
My rooflinings are also starting to come loose, I think it's par for the course, and it's an easy and relatively cheap job to get them re-lined. As jfm says the wall panels are probably a lot trickier.
Get the exhaust elbows done immediately, I had one fail and soot was drawn through the air filter and lined the intercooler, which then needed stripping. It also makes an almighty mess of the engine room.
Good idea to just tart up the existing teak for this season, a sharp chisel will remove the proud caulk in no time at all, you'll do the whole boat in 2 hours.
Great boat and I am sure there is nothing here that can't be put right. What I never understand for a vessel that is not too old at all is how owners allow lovely boats to end up like this in the first place. Amazing
Sounds like a lot of work ... aren't there any others you could look at that might not have these problems? There are 60 odd on Yachtworld.
It always seems like there are loads on the market but when you start to narrow them down to specific locations, year, engine choice, etc you can find that the pool shrinks drastically. And you can waste a lot of time and money trying to view every boat that looks like a potential candidate.
There are far worse. From what Jeremy says, it's pretty much all cosemtic or minor issues with the boat systems.
I believe it's also quite hard to keep on top of everything if a boat is kept abroad and the owner has limited time to devote to keeping a boat in A1 condition.
Its not so much about time as about money, Pete. Very few Med boat owners have the skill or the time or indeed the patience to sort parts and materials to keep their boats in A1 condition themselves. It is just so much more difficult compared to working on your boat in the UK and thats before you consider that the Med environment is much harsher on stuff like grp, upholstery and woodwork. So the Med owner is faced with 2 choices, either accept the fact that things deteriorate and only pay somebody to put them right when they actually stop you going boating, which seems to be what most owners do, or adopt a rigorous approach to pre-emptive maintenance and putting faults right as soon as they appear. Unfortunately the latter costs a load of money because either you need to employ crew or pay a trusted local to manage that maintenance
On my phone so possibly not the best of replies. Firstly thank you for all your input.
The boat has not been used since the end of last season so in terms of the snags these are mostly ( not all) startvof season gremlins.
The boat has been looked after very well mechanically. Always serviced with every bill. So my belief is it is a sound boat. The main expensive bits are teak and interior trim and these are universal for the boat. I looked at a similar age sunseeker and all the panels were sagging on that. So I don't really feel this one is un-typical.
Thanks to jfm for his detailed reply. I will use this as an opportunity to update the fabrics to current / different and will aim to do a cabin at a time. The saloon is generally good with a few exceptions so given its size here I will just restore in the original materials.
Fairline have given me the details from the build sheet so good call Pete.
Still with the vendor and I will see where we are on Monday.
