Daydream believer
Of course, which takes the hybrid even one step further.You don't motorsail?![]()
I did not realise I was so " green".
The art of selling by turning a limitation into a bonus. And "we're helping people be sailors and not diesel mechanics" ? Looks good to me though but i can't see it working for charter companies. I didn't hear them mention range on electric did I miss that? I heard him say "the electric community" though ?Yes, if you you look at this you will see that is
one of the big selling points by the US dealer.youtube.com/watch?v=jpAnGJpcnQU
Does that mean you'd be running a noisy stinky diesel just to cook?The boat, 32-34 feet, will be used for channel/N European/Biscay cruising.
The hybrid route would remove the need for gas on board. Inverter, induction hob and electric oven.
Propulsion batteries are likely to be 24V or even 48V so there is still a requirement for domestic supply... however there are ways round this, solution still coming into focus, removing domestic batteries equals big weight saving.
Range should not be a problem at all given that a generator is much more efficient than your average thumper, although of course there are downstream inefficiencies to contend with before you get to the prop. Overall the diesel consumption would be less.
Still thinking.
Downsides to a hybrid.
- More expensive to buy
- More expensive to repair
- More complex so more to break
- If you break down 100 miles east of nowhere you will have a problem A. getting parts B. finding someone that knows how to work on it.
If your boating plans are exclusively close to home or close to major boating centers where you can get service and you are ready for a big repair bill if something blows up then why not give it a go.
Vague on range, but probably 60 miles+ on fully charged bank, which begs the question of recharging as regeneration will not make much of a dent in that. So mains recharging seems inevitable. I could see this working for charter boats in Croatia where the boat hails from as they do have cruising areas with well spaced marinas and reasonable sailing winds. A week of sailing like in the video (without the rain) with an hour or two motoring and 4-6 hours sailing and a couple of overnights on shorepower could work.The art of selling by turning a limitation into a bonus. And "we're helping people be sailors and not diesel mechanics" ? Looks good to me though but i can't see it working for charter companies. I didn't hear them mention range on electric did I miss that? I heard him say "the electric community" though ?
Judging by this installationNot sure i would agree with that, other than the more expensive to buy bit (which is a huge factor).
Other than day sailers, it currently only really makes sense when looking at a new build 45 or so foot long distance cruiser.
Today that will typically have a large Diesel engine, plus a diesel generator, plus at least one Watt&Sea hydro generator - as well as solar.
Replacing that with a single diesel generator and one or two electric saildrives (with regen capability), plus a large battery setup, arguably makes for a simpler system ultimately to maintain. And electric drive motors are a very proven and simple technology.
However, it is true that to be efficient, all that lot will be microprocessor controlled - including the battery pack itself. So if anything does break won’t be a case of oily spanner fixes.
And one thing I have yet to get clarified is what happens if a large 100kWh suddenly gets inundated by salt water (eg due to a collision with underwater object). Been a very small number but very serious car battery fires after a rare crash combination. In theory the battery management electronics should protect the batteries from fire, but will these electronic safety features themselves fail if immersed in salt water? Mid ocean is not the place to discover the answer to that super fire risk question!
Energy density. It’s the reason the maths don’t work for electric boats and if you add cooking to the list of loads you just make things much worse.Judging by this installationall the batteries and control units fits in the space of a diesel engine. The motors are small so don't take much extra space under bunks. So size of boat might not be that critical for an electric only installation.
The ability to regenerate electricity is critical of course and the salesman here is claiming this boat already makes sense for "off grid" extended cruising, which it would if there was enough battery capacity for a decent range and if that could be recharged quickly. He said a couple of hours motoring would be recharged after 4 hours sailing, which gives a to be take with a pinch of salt guide anyway. If true and if in future the range could be taken to 100 miles motoring on calm days and recharged in a few windy days that would be plenty for nearly everyone.
The installation of the control units was about waist height so things would already be pretty near lifeboat time before thats an issue.
This new all electric boat has gas for cooking, must be a good reason they didn't use electric.
Yes, the range between stops is infinite miles assuming nothing breaks. Considerably better than diesel.I didn't hear them mention range on electric did I miss that?
It's also a nuisance to fire up for a short trip out of the marina and that doesn't do it much good either.
So ... hybrid. A 20 hp diesel with a 20hp electric motor can be used electric only to get in and out of marinas, diesel only for long trips or diesel + electric for mistimed trips through the Dorus Mor. Even with the motor it will take up less room that the diesel it replaces. The downside, of course, is that for half an hour of full electric power you need 650Ah of 12V battery capacity, which at the moment is either heavy (lead-acid) or expensive (lithium-ion).
People repeat this as some sort of statement of faith, but in my experience a lot of the time the engine is running for plenty long enough to reach full operating temperature. Maybe there are some marinas located so you only need the motor for 5 minutes, but I don't know them. Mostly the motor runs for 20 minutes or more while people get clear of the harbour and faff with sails.....
Also the damage done to diesels when they are only used to get out of the harbour whereupon the sails go up and the engine goes off is significant.
I don't understand this comment. How much of a nuisance is it to press a button to start the engine, then press a button to stop it?
No, you'd need much more battery capacity for a 20hp electric motor. It's likely to run on 96V and draw 150A or so.
As for the idea that it's bad for an engine to run at a fraction of its power, most cars will do 200k miles, on average they will be running at what? 15% of rated power and half the time under 100%.
Possibly the big picture is that dieseling around in a yacht at 10mpg will not be an acceptable activity before very long.
We could be looking at short range power just to get off the pontoon etc. A big Torqueedo and a couple of kWh of battery?
No generator, no complication.
Remember that I only suggested 30 minutes on electric. 20 hp = 15 kW. 15 kW for half an hour = 7500WH, which is 625Ah at 12V. Or less at 96V, or course, but that's wiring, not battery size.
Someone I know delivered an Oyster a few years ago which only had electric for cooking with no gas on board. They used to run the genset to run the cooker when on passage.Since this option was only raised a few days ago my ignorance is huge. The info from everyone on this thread is terrific, I thank you all.
Please don't hold back should anyone else have any input, all much appreciated.
does seem that electric cooking is out but I have always fancied the idea of a generator sited in the perfect position for weight distribution and no gear box. With battery technology improving so massively to have the ability to motor for and hour or two is a bonus and the efficiency of the likes of Watt&Sea is impressive.
My maths is superb. You need to take 650Ah out at 12V. How you achieve that is a different matter. Clearly you'd need a lot more that 650Ah if you were using lead acid, but not if you were using Li-ion.Your maths is too simplistic. Ever heard of Peukert?
