Need .5 metre of 102mm good quality exhaust Hose
B27
26 Jul 2023
Go to a boatyard that fits engines.
You might even find a used offcut which can be cut down.
PaulRainbow
16 May 2016
Suffolk
Doesn't an exhaust hose need an antisiphon loop,
Not necessarily, depends on the rest of the exhaust arrangement.
how do you engineer an antisiphon loop in 0.5m of hose, any hose let alone exhaust hose.
Jonathan
It seems somewhat unlikely that the distance from the engine to the exhaust outlet will only consist of 0.5m of 102mm hose. Chances are it will be something like the short section between the silencer and the outlet.
oldgit
6 Nov 2001
Medway
Needed, short length 30 cms x 102mm pipe from engine exhaust riser to the 45 degree exhaust hose elbow.
Already existing , 1.5m of 102mm from elbow to silencer, and a metre of 102mm from silencer to hull exhaust via monster antisiphon loop.
PaulRainbow
16 May 2016
Suffolk
I believe Volvo demands an anti siphon loop and the OPs installation HAS an antisiphon loop and he only needs the hose for part of the installation (to complete the loop).
Jonathan
Never known to be wrong, are you ?
I have two Volvo engines, no anti-siphon loops.
If the injection point on the exhaust mixer is above the water line there is no need for a siphon break.
