G
Guest
Guest
In light of the recent posts about ships, lookouts and yachts. Do you not think it is strange that the requirements for navigation lights have not really changed even though the relative speeds have?
Why is it that a small boat should have only little lights but a ship have bigger ones! It is still the same mark one eye ball that is looking at each other. (Unless you have sunglasses on)
Take the Aquasignal range for masthead lights:
Series 20 Masthead 5Watt <12metres Min Range 2nm
Series 25 Masthead 10Watt <12metres Min Range 2nm
Series 40 Masthead 25Watt <20metres Min Range 3nm
Series 55 Masthead 25Watt <50metres Min Range 5nm
Series 70 Masthead 40Watt >20meters Min Range 5nm
Obviously the ranges are their minimum standard. So a 25W bulb can be used in a light for 5nm range.
So why does anyone use anything less than the 50metres standard?
In particular LEDs! Absolute minimum requirements only. So you spend all that money just to make sure you can NOT be seen in time. Also fitting lights that will be the first thing to pack up in a lightning strike is strange.
Not trying to start the debate about LED (Yes I would like to, but not in this thread) But in general why do yachties think that it is good to wear all black clothing and walk across the M25? If you want a ship to miss you, then have the lights that will give them a chance at the 5nm range.
Running 70W computer, 30W radars and 50W high brightness screens and then using the equivalent of 5 and 10 watt navigation lights is not sensible.
As for the quality of some of the lights! The problem is that they are hard to seal due to temperature changes. So why are the contacts just unprotected copper strips. The main failure of navigation lights is due to the bulb holder resistances and corrosion of the contacts. The bulbs blow only when using very high boost charge voltages on the batteries or the holder allows them to vibrate. My bow lights take a dip quite often in the waves.
