markc
No there isn't' The case is sealed apart from the cable grommet.
Must be magic then. Perfect grounds to have a pointless argument. I know, I know...don't feed the trolls :encouragement:
it was a simple question that's all![]()
True, but I can remember at least a couple of boats where whoever installed the same radome drilled a hole inside the lower case, to route the cable directly inside the arch - I suppose to avoid leaving any part of the cable exposed to the elements.No there isn't' The case is sealed apart from the cable grommet.
Do these adapters grant a full integration? I mean, can a touch screen MFD show the radar signal coming from an old scanner, for instance?You can add new Raymarine equipment to legacy with adapters, so a new touch screen chart plotter could be added for example.
I give up.
Not at all. If you don’t know or understand a problem don’t offer an opinion that’s all.
Well J, I can see why you might criticize the tone - which is what "fait la musique", someone say...It does seem that DV is only here for an argument.
Have you got one of this on your roof![]()
Then you have radar!
