Nautor Swan flattener
johnspeetjens
8 Sep 2022
I have a Nautor Swan 46Mk1 and am thinking about removing the mainsail flattener so I can put a dinghy on the foredeck. Any thoughts?
dunedin
3 Feb 2004
Is it the inner forestay you are referring to (the only thing I can think of impacting storing a dinghy on the foredeck)?
The importance of this does vary slightly based upon the precise rig and sail set. But could be catastrophic to be removed if needed
Motor_Sailor
21 Jan 2017
Norfolk
I think they're more commonly called a babystay on rigs with in-line lower shrouds.
The problem with in-line rigs is that the mast can 'pump' when sailing hard in to lumpy seas. The support loads for the rig, that goes up from the mainsheet and then towards the lower mast fanning out through the sail material when close hauled, is opposed by the baby stay.
Some of these rigs also have a true inner forestay going to the second spreaders. With these the babystay is probably redundant, but if you just have the single forestay out with the roller genoa, then some experimentation might be required. My babystay could be removed which made gybing the spinnaker much simpler, but it, together with some higher aft checkstays, were needed in heavy weather to keep the mast in column.
thinwater
12 Dec 2013
Deale, MD, USA
sail-delmarva.blogspot.com
Davits. I've watched enough people frog around hoisting tenders on deck to know I would never do it.
If I can't fit davits, like my PDQ, then I use a kayak (what I do on my F-24).
Before removing the inner stay I would check with the rig designer. I know of a mast that failed by inversion.
Tranona
10 Nov 2007
Think you would be drummed out of the Brownies if you put davits on a Swan 46 - never mind the impracticality
