Nasa Clipper Echo Sounder and Seafarer Transducer
AndCur
9 Oct 2003
Hi Folks
Does anyone know if the Nasa Clipper Echo sounder will work with a old Seafarer transducer?
Thanks for replys
Andrew
JohnTH
7 Mar 2009
Dalgarven, Ayrshire
No, but if you have both items anyhow why not connect the two and see what happens.
Lots of other folk may be interested in the result of your experiments, keep up posted!
73s de
Johnth
[3889]
26 May 2003
I wired a clipper to an NKE transducer and it worked - NASA confirmed that cutting cable was not a problem.
VicS
13 Jul 2002
Pretty sure both are 150kHz
My old Seafarer 3 is and as far as I have been able to discover the Nasa clipper one is too .. your manual will verify that for you.
Leighb
8 Aug 2007
Suffolk
I can confirm that an old Seafarer transducer works fine with later NASA digital echosounders, and vice versa presumably.
DanTribe
8 Jan 2002
Essex
Hi Folks
Thanks for replys
Andrew
Mine does.
I had a spare Seafarer sounder so plugged it into a NASA transducer as a back up.
It works fine.
