NASA BM2 Problem
Esmerelda
30 Oct 2009
I tried fitting a NASA BM2 battery monitor today and ended up with a strange problem. When batteries were being discharged, the monitor showed it as charging and when I charged the batteries via the alternator it showed as discharging. The actual amounts of the ampage looked about right, it was the direction the monitor thought they were going in that was wrong!
Is anyone able to point me in a direction to look?
theoldsalt
24 Nov 2010
Bristol
The monitor measures the current through the shunt fitted to the negative terminal of the battery. The white and black wires both go to the shunt terminal nearest the battery negatve post and the yellow wires goes to the other (domestic negative load) side of the shunt.
If charge and discharge readings are reversed maybe you have wires crossed. http://www.nasamarine.com/images/Clipper BM1+BM2.pdf
Ric
8 Dec 2003
Sound like you have connected the shunt to the positive terminal of the batteries. On the NASA BM-2, the shunt should be connected to NEGATIVE terminal.
Excellent bit of kit by the way!
Esmerelda
30 Oct 2009
The shunt was connected to the negative terminal.
Could the fact that I had connected the battery monitor to the positive / negative just before the battery on / off switch rather than the battery terminals be a factor? (I know this isn't the right place to connect, but for the sake of convenience I thought I'd try it as the boat is new to us and I was struggling to see where the positive and negative battery cables went from battery to battery)
pvb
UK East Coast
Do you have an on/off switch in your negative lead?
Esmerelda
30 Oct 2009
It's a Sun Odyssey and has 3 battery switches, 2 red (engine and domestic batteries) and 1 black. The black switch was described as a negative general cut-off switch. I connected the BM to the terminals on the back of those switches on the side connected to the batteries
pvb
UK East Coast
If you did that, wouldn't the monitor register current in and out of all the batteries, rather than just the domestic batteries? If you want it to work as intended, you need to follow Nasa's wiring diagram.
theoldsalt
24 Nov 2010
Bristol
Thanks for reply - unfortunately that is not the answer - I had even tried swapping them around in desperation...
...... but are you sure you have wired the BM2 correctly to the wiring diagram as referenced in post 2. It should be followed exactly for correct operation.
Esmerelda
30 Oct 2009
I appreciate that the way I tried wiring it means it may not be 100% accurate, my question was really why would it effectively be working backwards?
VicS
13 Jul 2002
If it's reading back wards its because you have BM connection to the shunt incorrect
Connect the red and orange wires ( via fuses) to the house and starter battery +ve terminals respectively
Connect the shunt between the house battery negative and the negative isolator.
Connect the black and white wires to the end of the shunt that is connected to the battery and the yellow wire to the end connected to the negative isolator
There must be no other connections to the house battery negative terminal
NO IFs, NO BUTs ........ Like this:
VicS
13 Jul 2002
The correct wiring diagram was referenced in the manual in my post 2 so a hand written diagram is hardly clarifying things for the OP.
The pictorial representation of the wiring to which you refer in #2 does not show the battery isolating switches, inparticular the common negative isolator.
It is not absolutely clear from goliaths posts quite how he as wired the shunt to the battery negative and the negative isolator. My diagram clarifies how that should be.
I am so sorry a hand drawn diagram is not good enough for you.!
I am just hoping it might help to clarify something that your post #2 and reference to the illustration in the instruction manual. which he doubtless already has, clearly failed to do..
mjf107
13 Mar 2004
Well I've made a copy of it for future reference..... A picture paints a thousand words
VicS
13 Jul 2002
The important point to remember is that there must be no other connections to the (house) battery negative, or the end of the shunt connected to it, as noted on one of my earlier hand drawn offerings ( From pre starter battery monitoring days...... No orange wire)
