bluedragon
Mysterious \"growth\" under my mast step - HELP!
My newly acquired Halcyon 27 has a die cast Al alloy mast step mounted on a large block of teak sitting on top of the coach roof. I'm just in the process of replacing the wood due to aging and bowing. Today I removed the casting for possibly the first time in >20 years and was intrigued and a bit conerned by what I saw underneath. I can only describe it as an extensive growth of a hard mineral-like deposit, v.light brown in colour. This had "eaten" depressions into the teak to a depth of perhaps 5mm in places and to some extent into the underside of the Al casting. This deposit was wet and powdery in places, and quite stone-like in others. I was able to remove it by scraping. Does anybody have any idea what this is, what caused it, and how to avoid when I re-assemble everything with a new Iroko block?? The casting was attached to the block with SS wood screws. These did not show any signicant corrosion much to my surprise, neither did the casting around the holes. It seems to be a reaction between the Al casting and the teak brought about by a moist / salty environment over the years.
