pvb
Being aground is fairly normal in these parts, too!![]()
It doesn't have to be - just depends on your level of risk aversion.
31' and Fin keel, so a half-tide mooring is not suitable. I'd have to be on the pontoons at Brightlingsea.How big and what type of keel. My 25ft bilge keeler costs just £190/annum on a half tide mooring at Brightlingsea. Good sheletered mooring with good access to some nice estuaries to explore.
Sadly, I'd be seriously aground in 1 metre of water - Capricious draws about 1.6 m (1.5 metres officially; 1.6 to be safe!), and has a fin keel, so taking the ground isn't an option.
The expanded metal is no worse than the recycled GRP at our present marina for kneeling on. At least it isn't as slippery as wood!
Annnnd - - - you'll find - with the expanded metal surface on the pontoons the muck on folks deckies tends to clean off as you scuff along - plus any rain washes dirt through the holes - - it all keeps the boat just a bit cleaner.
OK, I'm beginning to plan the move. I've pretty much decided to sail her down, via the Caledonian Canal. I did consider the Forth and Clyde, but a) Capricious' fresh-water draft is pretty much on the limit and b) it means taking the mast up and down, and creating some kind of mast support.
I'll contact people directly about crewing; some places are already filled. I don't think I'll need crew from the Clyde to Inverness; from there on there will be one or two spaces.
Time will be from the end of March, and I hope to complete the trip in 3 weeks, or not too much more. That's not sailing every day; at present I reckon 16 days sailing, allowing a few days rest or shelter from weather.
I'm not familiar with the East Coast south of Eyemouth, so suggestions about suitable ports for overnight stays and crew changes would be appreciated. I'm reckoning on about 60 nm a day, and reckon that Whitby, Grimsby and Lowestoft (or Yarmouth) are the only possible choices for the last stops before Titchmarsh; basically there isn't anywhere else suitable for Capricious! Of course, Grimsby-Lowestoft is a long haul, but I think that planning on getting Capricious into Wells is a bit iffy!
I have a chart-plotter with UK charts, but I'd appreciate people's advice on which charts and/or pilots would be most useful for the passage. I don't want to over-buy, as most of them will only be used once! At present I'm inclined to get the 1:750,000 North Sea charts and use them for planning and so on. I prefer Admiralty charts, on the whole, but I'm not that fussy.
Avoid Great Yarmouth like the plague,
In addition to what's been mentioned - south of Eyemouth believe Blyth and Sunderland are pretty much "all states" and easy to get into.
Don't dismiss Wells out of hand because of it's reputation - they dredge the channel now because of the wind farm boats - also the HM will come out and guide you in - understand also they've dredged at the pontoons so have more depth - - it's worth a phone call to the HM to ask his advice.
I've been trying to choose destinations that are all-weather and all-tide as far as possible, and for this trip I'm being conservative. In fact, Wells would be on my list of potential cruising destinations once based down there - but as a destination at the end of a long haul from (probably) Grimsby, it has too much chance of not working out.
