Clyde_Wanderer
Does anyone remember a few wks ago, I posted a question about my keel been loose?
Well I have had a surveyer have a look at it, and inside the boat, he reckons its the hull either side of the keel that is flexing, and not a loose keel.
But I am not sure, as I wonder how he can make this diagnoses with her sitting on her cradle and the keel resting on the cradle centre spine, ie, without been able to meve the keel.
He advices cutting out the interior floor moulding which has small cross floors, ( or bulkheads running transversley underneath ) each about 13-14" longx7-8"high and which also supports the inner floor, these bulkheads are laminated onto the top surface of the hull and keel seat, and are shaped like a pair of Y fronts, "for want of a better description".
Two of these BHs have small areas of delamination, which were noticed in a survey done 3 yrs ago, but described as imaterial by the then surveyer.
The point I am making is that there is no other clues as to a weakness in this area of the hull, which leads me to think that I am been incorrectly adviced.
I would have thought that if there was recent flexing of hull that the lamination between bulkheads and hull layup would show signs of sliding or movement.
I have been adviced to relaminate hull across keel area and up a couple of feet either side on hull, which i reckon I will have to remove keel to do this work, as the studs would get in the way of this laminating, Which in doing that would still cover the surveyer if it did turn out to be a loose keel anyway.
Can anyone advice what I should do, or describe the process I should follow, to carry out the relamination work successfully?
