JoeCruiser
Advert has been online for months. Search Ariana 31m for sale and you will find advert. They wanted 1.2m Euro originally and then dropped it to 900k Euro. It’s certainly a lot of boat for the money.
I believe the 2 crew are Turkish. She was sailed from Turkey to the Med every year for the summer under the first owner. Hence the high engine hours.
I was told she has not been a charter boat. It changed hands for the first time in May 2018. From it’s build to May 2018 it was with the same first owner.
Regarding the engines being older then 2006, the boat was probably in build for a year and the engines may have been sourced prior. I will find out.
the broker who has known the boat from new says the fuel burn rate is 130 per hour for both engines. I have no idea if he is correct or not. It does seem low. Either way it’s not a deciding factor.
now that you have seen the advert. What are the pitfalls I am to expect if I jump into a boat like that?
what can anyone tell me about the Wood epoxy build that I should be very concerned about? Should a good surveyor not be able to do some background check on the 2016 repaint and carry out a hull survey?
I don’t agree with the statement someone made in this thread that one needs to budget to replace the big ticket items once every 6 years! Yes some big ticket items will fail. However as long as it’s not an engine packing in its likely to be under £30,000 to replace the faulty item. Anyone owning a well equipped 60 foot plus boat out of warranty is aware he could get hit with a 15k unexpected bill at any time. So a £30,000 unexpected bill on a 100 foot yacht doesn’t seem too bad.
If offered for charter, due to the low purchase price it can afford be priced very keenly.
