Tranona
Question for wheelists.
Just about to convert from stick to wheel on a newly acquired yacht. The steering is wire from binnacle to steering gear in aft cabin.
Should the wire fail, is there a way of manually steering in such an emergency? If so what does this entail?
It is a requirement of the RCD that an alternative means of steering is fitted. Normally this is an extension upwards of the stock to take a tiller arm - usually on a square. Often not very effective as there is insufficient room to swing a long enough tiller. On my boat it also faces aft. Even more difficult with an aft cabin unless you are able to take the stock through cabin roof. So, normally the extension comes to bunk level and you need a second person to do the steering from inside the cabin.
An effective form of alternate steering is an autopilot with a drive direct to the quadrant, although of course this depends on an electrical supply.
Fortunately on a well designed and maintained boat there should never be a need for emergency steering!
