lpdsn
Unless your wheel is only a single turn lock to lock then it's not quite that simple.
Mine is only 3/4 turn each way to full lock. I can't imagine needing more, but I guess larger boats might.
I've never seen a tiller used at an inside steering position. I suspect it might be a tad inconvenient to use.
Put a Turk's head on the wheel - easy to slide your hand around and find centre without even looking.
Whipstaff instead?
Mike.
I think it depends very much on the type of sailing you do. Our first two boats were both tiller steered and we were happy with them - but they were 18 foot and 27 foot, and a long passage was 20 miles. As we got more experienced, we got more ambitious and moved up in size - 33 foot and now 43 foot. We also are going further afield - passages of 60 miles or more - including multiple days at sea. Both the larger boats have been wheel steering and I could not imagine helming anything so large with a tiller, or helming for so long or so far on a tiller. There are a few times when we miss "something small and wet", but we could not possibly justify having two boats and the primary requirement is for a reasonably large cruiser with good accommodation. YMMV.
Difficult to generalise. An old style fishing bawley with tiller steering is anything but a pleasure to steer, probably needing tiller lines to control it in anything of a blow. Likewise I expect that Fisher will be pretty boring to steer from inside. On the other hand a modern fin keel boat with a big balanced spade rudder and a direct wheel steering system can be a delight (like my Bavaria).
You soon get used to steering with a wheel and appreciate its advantages. However there are of course boats around the 30-35' mark where either a tiller or a wheel will work and for some the tiller may well be more appropriate.
It really depends upon the size of the boat. There's certainly fun to be had steering a larger boat by wheel, even with the weight of twin wheels. A larger racer, of the type with the huge wheel in the cockpit, will give you the precision and feel of a tiller at a size you couldn't manage with a tiller.
... Close quarters and going astern I find much more tricky with a wheel, the reference with dead ahead/astern is almost lost. ....
But that still means 1/2 turn of ambiguity: 3/4 left = 1/4 right to v.v....
Mike.
I have had both types. The feeling when a tiller steered yacht comes alive under sail is marvellous and I have not felt this on any wheel steered boat. Having said that I would not like to swap my wheel and padastal mounted nav display for the sort of cruising I do. If you tend go go out on shortish trips in familiar waters I would try for a tiller.
Wheel. You are encouraged to sit to leeward when going to windward. The helm position is often too far aft and exposed, and you can't drink tea and eat cake at the same time when helming. That's about it really.
Are you John Cooper Clarke?
