jon_bailey
I know this subject has been done to death but I have not found a solution to my particular problem.
Trying to mount the tranducer for a Garmin 240 Blue as a shoot-thru hull device on my Maxum. The problem is that the only places to mount transducer on inside of hull is sloping (by at least 20 degrees). To resolve this I cut a tube off at correct angle, sealed to hull and then filled with water before mounting tranducer level in the tube.
On last trip out depth shown was in accordance with factory fitted depth gauge but there was a lot of noise in the top third of the trace and certainly much more than on other fishfinders I have seen. I have the following questions:
1) Is this noise likely to be caused by the fact that the transducer is not bonded to the hull and not aided by the fact that the face of the transducer is at varying distances from the hull due to the slope?
2) If the transducer has to be mounted horizontally then how can this be done on a sloping hull?
As always, all advice gratefully received.
