pandos
Me too...hard to get the spam stopped...I gave up with John Harries's rants some years ago and have no plans to return.
Anybody going let on what the failure was? Being a Spade user for the last 20 years, I have an interest
Did you really feel frightened by a 35 knot gust?I did some rode tension work in a developing Seabreeze in Sydney. Usually its glorious - blue skies but becoming choppy if not sheltered.
I had chosen a location where our cat was only subject to wind, not chop. I did a series of tests at different scopes.
One of the series I recorded a tension of 650kg developed from a 35 knot gust. It was frightening and I chickened out. I was afraid something would fail (it did - my courage). I likened it to driving your yacht into a brick wall.
Add lateral loads, a good, well set anchor, no snubber and you could bend a shank.
It was all part of my work on snubbers.
I've seen bent anchors - but unless I know the background I tend to treat them as a one off. If I were to see a series - I'd want to report them. Today most bent anchors are exceptional. We are lucky - makers of anchors have learnt lessons, from each other - and we can thank Peter Smith for much of the education.
I forgot
I did another series of tests where I set 15kg anchors to a tension of 500kg, straight line pull. I then took a 4x4 and snatch loaded the anchors. I bent the shank of Spade, SARCA, Fortress (FX23) and totally destroyed an aluminium Excel. The exception was a steel Excel Bis800 shank, as good as new. Fortress sent me a new shank, Anchor Right completely re-designed their aluminium Excel and gave me a new one - which we then used for over 10 years.
Jonathan
Must have been very thin chain to develop dynamic loads like that. Though if the load cell wasn't calibrated the error could have been pretty substantial as well.Did you really feel frightened by a 35 knot gust?
That's just one example. He's American. They can't see any middle ground, this or that, all or nothing. Cultural thing
No, I feel frightened with a 650kg snatch load.Did you really feel frightened by a 35 knot gust?
You have bent over backwards to answer my questions with fulsome answers and extraordinary detail.Anybody going let on what the failure was? Being a Spade user for the last 20 years, I have an interest
Load cells are never accurate enough for commercial use. That's why calibration is important. They should have supplied you with a calibration sheet similar in concept to a deviation sheet for a compass. The cell might over read on some loads but under read on others, company I used had accurate test weights to provide the load.The load cell had been tested for accuracy by Robertsons - who are a NATA approved testing facility.
I have no idea what maximum load I have had on my anchor/boat. With a relatively heavy ketch, and relatively heavy anchor chain, we simply do not do "snatch loads".No, I feel frightened with a 650kg snatch load.
It was 8mm chain, no snubber but a Dyneema bridle. 3:1 scope, I was intentionally looking for worst case scenario - and found it.
In real life you would not anchor with a 3:1 scope under the conditions. But people do anchor for benign conditions, others come and anchor nearby until you become boxed in (and/or are not on the boat) - a thunderstorm comes through and you cannot lengthen the rode, there is nowhere to run to.
This is what happened to a couple in a cat in the Caribbean, (sailed from France and later I had contact with them when they arrived NZ) - they were on the beach, a thunderstorm came through, their anchor shank bent (it was one of the infamous bendy shank batch - which is why I know about it). It takes a decent snatch load to bend even one of the bendy shank anchors.
You can anchor in places in the Scottish islands in perfect safety until the winds pick up and suddenly williwaws developed as the wind is funnelled and focussed down valleys - commonly described as 'bullets' - first one valley then another - your yacht yaws with each bullet. You soon learn it was the wrong safe haven - but that does not help you 'at the time'.
In the article to which I often provide links of a sudden storm in the Med their Witchard hook for their snubber bent - its a yacht, bad things, unexpectedly, happen
In real life I would never anchor without a snubber/bridle - but I see plenty who do anchor without a snubber or totally inadequate bridle. Our 'hook' a bridle plate is either made from Bis80 or Duplex stainless (we have both). The Witchard hook, I suspect, is 304 or 316 stainless and normally fails because the retaining pin bends and you cannot realise the chain.
If someone anchors 'too' close behind us - we don't winge - we move, its easier. We prefer to be anchored in as close to perfect isolation as possible. If people do not realise they are anchor too close - then you are not going to convince them of their error and they simply get bad tempered. We once had someone close and he asked 'was he too close' my answer was simple 'if you are close enough we can have a conversation without shouting - you are too close'. We still moved - its easier for us than for someone that insufficiently knowledgeable.
The load cell had been tested for accuracy by Robertsons - who are a NATA approved testing facility. Robertsons did most of my chain and shackle testing and I simply included the load cell as part of the financial deal that I arranged with them. I confess it has not been tested recently - but then I have not used it recently.
Jonathan
I'm Anglosaxon and find quite a few Americans (USA type) black and white with views. They either really like something or don't. There doesn't seem to be a 'grey' area view. I could say that my anchor, Rocna, is the best and you shouldn't use any other, but for years I anchored quite happily with a Danforth 'copy' and I know that others use a variety of anchors with no problems. Luckily where I sail and anchor there are normally plenty of safe places to go if the weather turns bad. Shallow draft also greatly helps.A genuine question by a non-anglosaxon.
I am sure their site is interesting, but reading sentences expressed therein in a very pompous way like "We have withdrawn our recommendation for" this or that, or all this self-incensing relevance attributed to every phrase they write... In cultural places not having this American approach it simply makes everyone laugh out loud.
Have Americans discovered doubt yet?
Do they know there are hundreds of people sailing their own way, with their own anchors or whatever equipment "not being recommended" (or not waiting for any recommendation) and having a perfectly fine time? (I include hundred of sailors in the Arctic, Antarctic, possibly Venusarctic Marsarctic et al).
Anyway, the success of their site means there is a market for everything![]()
We have had severe snatch loads on our 18/19t ketch at anchor that have been dealt with by the snubber, usually.I have no idea what maximum load I have had on my anchor/boat. With a relatively heavy ketch, and relatively heavy anchor chain, we simply do not do "snatch loads".
I can well imagine that a lightweight, shallow draft, high windage boat will skitter about in every squall, and therefore has to be treated and equipped differently.
AIUI he's Canadian brought up in BermudaThat's just one example. He's American. They can't see any middle ground, this or that, all or nothing. Cultural thing![]()
Close enoughAIUI he's Canadian brought up in Bermuda
Something like the more you know, the less you are certain...
There's a favourite quote by Bertrand Russell about people who are cock sure about everything and those that are full of doubt..
Close enough
Or maybe we're being unfair & he is extremely clever in formatting the content to be popular in the large black and white USA market
not quite, he was a little more forcefulSomething like the more you know, the less you are certain
Dunning-Kruger syndrome in reverse. I don't know of a Bertrand Russell quote, but WB Yeats gave us:Something like the more you know, the less you are certain
There's a big problem with online content proclaiming to be "the way it is". You are now under a lot of pressure to kick out new content each and every week instead of really digging deep & looking into patterns in the universe at your own pace. Which again on morganscloud was why the comments could be very interesting, tap into a massive pool of experience & opinions to agree with or not. Every day's a school day.You now have a customer base paying a subscription who expect a constant stream of new insights.
Memento Mori ('remember you must die')
Might be wrong though....
