Ian_Edwards
My Southerly came with a CanBus system made EmpirBus, it now 12 years old and I need to test some parts of it.
I have the EmpirBus configuration software running on a laptop and the USB to CanBus interface, so I can see what's going on on the bus and change things around. I also have a spare base module and a couple of spare I/O boards.
I'm working towards setting up a simple system on "on the kitchen table", with just one module and then swapping out I/O boards to find out which ones are faulty.
I plan to use 8 momentary switches on the input and LED's to shown when the output MOSFET's have switch on or off.
I could build something out of discrete components, individual switches and LED's with current limiting resistors. It's a nominal 12 volt system, driven from a small AGM scooter battery. However, it would be much easier and quicker if I could find a membrane switch panel with 8 switches or more and an array of LED's, preferable running directly off 12 volts.
I've spent some time searching the net without finding anything which would make building the test harness quicker and easier to build.
What do those who play with micro controllers, Raspberry Pie's or similar use to test their projects?
Has anyone any ideas on where I could buy appropriate modules?
