Mixing gloss and Satin varnish
Kiwi 2018
5 Jun 2024
Hi- has anyone tried to add in a small amount of gloss varnish into satin to give it a little bit more of a sheen.
kacecar
29 Oct 2007
UK
Yes I have. Worked resonably well.
At the time I was trying to revarnish the saloon table and touch-up other bits of the woodwork in my elderly Sigma362. The standard finish was glossier than "satin" but nowhere near as glossy as "gloss". I used common-or-garden Ronseal Outdoor varnish (oil based) and a rather imprecise mixing method. I tried various proportions of satin and gloss varnish and produced a hardwood test strip which, when dry, was compared with the original, standard finish. I chose what I felt was the best match with the existing woodwork - in my case it was a 50/50 mix, although the difference between the eventual 50/50 mix and a 40/60 and a 60/40 was, for me, hard to detect.
The results were OK rather than brilliant. It looked fine on the saloon table, where I revarnished all surfaces but patching other worn areas was less successful, as any difference between the old and newly mixed finish (very difficult to get a precise match I suspect) really stands out. That said, the results were good enough for me to live with.
dansaskip
12 Nov 2004
Various
seabear.uk
Never mixed them wet as it were but have used a couple of coats (or more) of gloss then a final coat of satin (both) epifanes which I have found to give a very satisfactory result.
