MapisM
Yep, you perfectly spotted the weak point of the hawseholes on the sides.Regarding the hawsehole placement, isn't the side facing ones you have a bit excessive and demanding "rich" space to use them? Unless you cross them over to the other side (as in line from port hawsehole going over the bathing platform to the stbrd bollard in the deck), slightly confused there...
In fact, below is a pic of how they work with crossed lines, and in this respect the hawseholes in the transom are definitely better.
I might still use the upper (steel) cleats on the coamings, but their raised position interferes with the passerelle.
All considered, I think your idea to leave the hawseholes where they are and the lower cleats as well is a good one.
Re. the winch(es), you might also consider fitting just one on one side.
If you don't have any fixed obstruction in the middle of the cockpit, you can always use it also for the line on the opposite side.
BartW has this type of setup on BA, for instance.
