burgundyben
Vas - how many of those drums we're your epoxy? All of them?
Unless I find similar sized round (~280mm dia) portholes at 100euro a pop (need 10 of them!) just restore as much as I can the existing onesThanks Vas. What did you decide to do about your portholes?
Did you find anyone capable of re-anodising?Unless I find similar sized round (~280mm dia) portholes at 100euro a pop (need 10 of them!) just restore as much as I can the existing ones
It's easy to remove them even in the water, so not restricted too much on what to do later on.
yep, But and that's a big BUT there's bits of metal missing, I've got a good and cheap welder that can weld in material however there are tiny weld spots left once you sand them down. Not much I can do about it unless I can get some liquid ali and try it out.Did you find anyone capable of re-anodising?
Yep, congratulations on 2 years hard graft, and real progress with your boat. It looks like you have broken the back of the project, and should be on course to finish off next season. Something to look forward to!
No! Vas can't be allowed to finish, what will we have to look forward to on here![]()
Hi Vas,
Definitely celebrated IMHO!
What you've completed so far - the epic amount of effort and commitment is a great achievement and well worth a celebration in itself. I won't ask if you would have started on it if you knew how much was involved however...I'm sure you'll find the launch celebration all the more enjoyable when you look back at all that you've refurbished, repaired and renewed - content in the knowledge she'll be good for a long while and you can sit back and enjoy. (However long it takes to get to that point.)
Temperatures of 12-15C sound positively warm to me as I ponder how to raise from 7C so I'll be able to get resin to cure...
thanks Paul for the kind words, I really should make it this coming summerYep, congratulations on 2 years hard graft, and real progress with your boat. It looks like you have broken the back of the project, and should be on course to finish off next season. Something to look forward to!
Vas
Re two years on the hard.....
When I rebuilt Little Ship it took me three years of total commitment.
As for ongoing jobs after launching.
I'm now 10 years into that
Keep going..... It never ends.
Tom
I'm not sure to understand your concern, V.This sidewall/ledge whatever is around 550mm high at the sides, 620mm in the middle where the passerelle will be bolted on. This means that the cleats will be around 350mm higher than currently placed, or in other words, 1200mm from waterline. Mind my permanent mooring spot is around 400mm from the waterline, so lines have to climb up a bit but not much. From a quick check along the marina here, most 45+ mobos do have such a slope in their mooring lines and noone seems to bother.
Am I missing something or should I go ahead with that?
Aha, I see what you mean. Oc course, there isn't such thing as THE right or wrong setup.MM, I see the point in keeping the hawseholes and lower cleats for cross lines and add a couple of cleats and fairleads as described BUT I'm going to loose 1m of seating![]()
