stuhaynes
In view of all the problems I've had with my water pump pressure switch I've decided to fit an in line one. The one I've got is a Whale W7207. To deal with 24 volts @ 6amps I've ordered a SPDT button microswitch,22A 150degC from RS to replace the weedy thing that is in the switch.
Can anyone who knows more about micro switches than I do suggest whether the new micro switch is going to be man enough?
I should point out that the 'new' in line switch is one that I found on board. It's been used and the micro switch was corroded
