Seajet
And I'm not one of them; I do know a bit about aircraft and systems though, military and civil.
You're not the only one. But you are talking out of your tailpipe here.
Maybe there are systems that were capable of tracking this flight but there is a big difference between having the technical capability to do something specific if you want to do it and looking back after the fact. You would have us believe that every flight that is identified as being a non-threat is tracked? There are 100,000 flights per day in the world. I simply don't believe that any government or military has operating procedures that require them to track flights that are positively identified as commercial and non-threatening.
Believe what you will, but you sound like "one of them".
the fact is the aircraft must have been on several state of the art ground radars, let alone satellites.
IIRC, duralamin is an Al/Cu alloy, so maybe the Cu is antifouling.
After being tracked by conventional radar of the Malaysian and Thai military, both have equipment with a range not much over 250nm, depending on the aircraft's altitude. By that time the normal airborne transponders had been turned off so no data was being transmitted, other than the engine monitor whose pings were picked up via the INMARSAT satellite for a further 7 hours and which furnished the potential Indian Ocean path. No satellite is known to have any radar functionality that would track normal commercial aircraft in flight.
Once beyond the conventional radar range, only the over-the-horizon system, JORN2 in Western Australia, would have a chance to have detected the flight, but its range is quoted as being 3000km and the believed flight path was beyond that.
What, exactly, do you then believe? As a one-time engineer specialised on communications engineering and then, after a further computer science degree course, working on the Fylingdales BMEWS radar system maintaining its software control systems, I too "know a bit" and the account I quoted fits the facts in my mind. Perhaps you could enlighten me on where I am being misled? I would like to know what you know and I do not - seriously.If you believe quoted coverage by classified sensitive resources like RORSAT's, spiffing; I and a few ex military & / or airliner pilot chums don't.
Wasn't RORSAT a Russian series of satellites? They finished operations in 1988 and were intended to track NATO shipping. They would need a different kind of radar for tracking aircraft rather than ships. They were low earth orbit too, so even if one were still operating, it would be a lucky glimpse to see MH370. Sadly, those nuclear reactors are still in space amongst the other junk, due down in 600 years.RORSAT's can indeed discriminate aircraft, it's rather handy being able to give a ' God's eye view ' even if originally set up only to observe fleet dispositions etc, but I expect you know there's a helluva lot more capability than that.
I'm sorry, you give no facts whatsoever why I should disbelieve the official line that I quoted above, that no tracking of MH370 occurred after it passed beyond the range of Malaysian and Thai military radar. As others have pointed out, there is no feasible reason to use satellite-based radar technology to try to track the many thousands of civil aircraft plying their world-wide courses over the planet - constantly and continuously with all the power requirements that would need, unlike the short intermittent bursts used to measure wave heights, for example, and I would not expect such functionality to be in use. For that the present transponder technology suffices utilising, as it does, receiver equipment only. If, as with MH370, the transponder is turned off, tracking by satellite is lost and it will be also lost to all land-based radar when far enough out to sea. There is no known system that could have monitored a silent radio frequency body at normal airliner altitude over the Indian Ocean if beyond the range of the Australian OTH radar system.With your background you should know, just use a little imagination as to Tempus Fugit, and satellites; among other things which go very high, very fast; I am not referring to SR71 but think on those lines modern day, but that would indeed be pure luck even with that coverage - mainly sats and the ground radar in that area.
However, MH370 wasn't entirely a silent body, despite someone on board disabling the ACARS reporting system the hourly interrogation by the INMARSAT satellite was receiving an automatic handshake response for 7 hours after the aircraft had ceased all other communications. From the analysis of the time between request and response it is possible to work out the distance of the plane from the satellite and which established its path deep into the Indian Ocean.
Too bad for all the conspiracy theorists that Diego Garcia isn't anywhere on that path.
A strange and uncharacteristic silence on the subject from a prolific poster. Either he's given me up as a lost cause, totally under the lizards' spell, or, in a vain search for some actual facts to support a fantasy, giving the subject some serious thought, research and revision.Unfortunately you're flogging a dead horse wearing a tinfoil hat here.
Barnac1e,
if it's me you're referring to I was rather hoping you'd look it all up yourself; quite seriously I have a busy day so will only bother supplying the details if I end up with free time, otherwise why don't you look it all up ?!
>I am amazed at how little fouling there is on the metal surface
It had Barnacles encrusted on the surface of the Flaperon which they think a chemicala analysis might place where the wreckage is.
Firstly please dont waste space talking about why or how MH370 ended up in the drink. That is for other fora/forums. This thread is about fouling or lack thereof.I also believe from what I read that the flaperon had been out of the water for quite some time before the penny dropped as to where it might have originated. In that time UV had plenty of time to degrade growth on it and indeed the mollusc shells on it look well bleached to me......allowing for the brief glimpse I was getting on the telly, and not being a mollusc expert either...etc etc.
Tim
