Keithleask
Hi guys just looking for a bit of advice, I am going to install a raymarine E 127 plotter as part of a general upgrade to a 94 sunseeker this is amongst a whole load of other things I am upgrading, of which more later. , ! Along with the E127 I am fitting a. Speed, depth, temperature transducer that will plug straight into the 127 . I have quite a few bits that I think I can do away with which will help to position the plotter at the helm. It means I have to re locate all the 12 volt switches which is. Ok as I am replacing these with logo type contura v switches anyway.i have a Stowe depth sounder and a seperate log which the E 127 can display on the one MFD. Would you guys keep the original kit as a back up or rely on the one bit of kit to serve all, just seems I have a lot of kit that I would not use including a simrad plotter that I have never used . I also have a Raytheon radar (analogue) that I will replace with a digItal raymarine radome ( HD maybe)!that I can display on the MFD as well so I can lose the Raytheon as well as it is analogue. Another more tricky issue is getting data from the engines to the MFD, I have KAD 42bs and am not sure if I can get data from these engines or not. I know raymarine do an EC 100 that will pick up data and transfer it but not from KAD 42 s I think ? Sorry if the above is a bit long winded but if you never ask?
