steve yates
I fixed up my cabin lights then ran the cables from them to the switch panel when it suddenly occured to me that I need to get both positives onto the same spade terminal if I want the switch to supply power to both cabin lights. (the lights have individual on/off switches so I dont always need both on) The negative cables are no problem as there is plenty of room on the busbar. I'm wondering about using a suitable wago connector that might take two wires on one side and one on the other? or can I crimp two wires into one female spade terminal? The cables are 1.5mm. I have seen what looks like a connector block before, but has multiple spade connectors joing one point, but I cant find anything like that on 12v planet or on google as I dont know the right word for it. I was hoping to avoid adding anything else like connector blocks into the switch box as there are enough switches for most everything to have its own.
