Merry Fisher 855 Cruising speed
Thomas Lewis
New Member
1 Sep 2019
Hello does anyone know the average displacement cruising speed of a merry Fisher 855 with twin Yamaha 150s. And also the cruising speed where at which it is most economical.
Hull speed will be about 7kn I would think. Most economical will likely be as slow as it will go! It will drink fuel between Hull speed and fully planing. Between fully planing and nearly flat out the mpg probably won't vary a lot but most economical planing speed depends on engine and Hull design.
Based on your power to weight ratio of around 90bhp per tonne (almost identical to my 7 metre boat with 200 hp). I would expect 20 knots to be the most economical cruising speed. As mentioned, once you are on the plane then fuel consumption is pretty much proportional to speed.
My new years resolution is to cruise at 27 knots rather than 20 - I'll use similar amount of fuel, arrive early and the boat quite likes that speed (as do i)!!!
Economy will also depend on the props being correctly pitched. If the engines are significantly under or over propped both fuel consumption and engine life longevity will be compromised.
