PalmaTarga
It's the berth (lease) holders responsibility in Puerto Portals.
curious J,
isn't the "master" chain nicely set in mud in Antibes?
how far off the bow is the shackle?
I had to put my own ground kit in Volos port, no main chain to link to, so a 90kg and a 40kg anchor on two massive chains around 30m long and then two thickish lines coming up to the bow (around 20m) so the main link would be something around 50m from the bow and always in the mud. Doubt there's going to be much movement in there to wear the shackle!
V.
curious J,
V.
All this concept of NOT having the marina fully in charge of the whole "in the water" (for lack of better wording) mooring system sounds totally silly, to me.
Aside from being obviously a rip-off, as if most of you folks wouldn't already be paying a LOT of money, it is also completely illogical.
In my marina (but I'm also aware of many others, at least in IT), when they make the yearly check of the ground lines, the diver also checks everything else: big bottom chains, weights in between them, berth-specific chains, lines - the whole lot.
If it isn't obvious that this is a MUCH more efficient and consistent way to handle that, I don't know what else can be called obvious!
Btw, I suppose there must be some fine print in the contracts you signed, specifying that the ground line maintenance is your responsibility.
Now, if your or other boats would be damaged due to a bow line that let go because not properly maintained, isn't that something the insurance could take as a good excuse for not covering the accident? :ambivalence:
Just wondering - far from wishing this to anyone, of course.
Yes well in most the ground tackle is regularly inspected / maintained etc .
But in PV there s some recent political background stuff regarding the new management ( local authorities) .
That might have some play the treatment of JTB ,s predicament??
The management are looking at increasing revenue streams where they can get away with it .
@ JTM is there a berth holders group? If so do they have managements ear ?
You can’t be the only one if the marina ain’t regularly inspecting ground tackle ?
Aiui it has always been the leaseholders responsibility at PV, even before Vauban21 took over the management. However one 'initiative' that the new management have implemented is to replace all the lazy lines, quai by quai, to colour-coded green/red lines. And then charge the leaseholder for the work - regardless of the condition of the lazy lines that were removed. This is apparently causing some friction.... (they haven't got to my quai yet).
Yes there is a leaseholders association, and I am a member, but they don't seem to have much traction with the new management.
I disagree, P: forget the colour coded lines.
That's just a side show, though I suppose it's convenient to know what you are handling at any time, rather than only when you reach the cable ties.
The real difference is in the responsibility.
I'd rather pay the marina and know that they are in charge in case of any "bow side failure" (so to speak), rather than be personally responsible for a job I have to pay (and trust) a diver to handle anyhow.
Of course, my first choice would still be for having the marina fully in charge and pay nothing on top of the normal mooring, but at the end of the day whether the total fee is split in different components or is an all-in amount is just a matter of accounting...
I don't disagree that the responsibility is the main point here. To me it's just nuts that Jimmy and others are being made responsible for ground lines. I suspect that if I asked the marina if I am responsible for the ground lines they'd think I was nuts. Whether that's because I'm only an impoverished renter or we're not in rip-off France / Mallorca I don't know.
