vas
evening all, I think this one is for ARE but open to discussion as always
so, my MASE IS8 (or something like that) generator is back in business after a complete overhaul of the Yanmar 2GM motor.
It's a 3K rpm motor with closed cooling circuit.
Ordered a linear actuator that I'm going to use to up and lower and generally regulate rpm to avoid having to rebuilt it in another 1k hours (if i ever do that)
Two issues I'm trying to address is:
1. what/how to cut output during low rpm warming and cooling periods
2. charge a 60-70Ah starter battery for the thing
Now, bear with me, all literature on the MASE show a completely different generator at the back so all wiring/connections/etc are completely wrong. Going to the MECC ALTE site and literature I get no info on the high current layout/wiring/etc. So I'm slightly stuck
Took a couple of pics of the box and it definitely looks like an old school thing with two LARGE capacitors (as in 100mm long and around 40mm in dia) and a 4 terminal take off with the wiring coming from the innards of the generator going to the two schuko sockets and two tiny wires going to the Vmeter that doesn't work.
Further the two terminals that you're meant to connect the battery to charge it from the whatever secondary coil of the generator are there but the cables at the back go nowhere, just hanging there (cut some tie wraps that were holding them securely to the rest of the cabling just to make sure they are the ones...)
So looks like I have no Automatic Voltage Regulator, is that too bad, no idea, thing works anyway!
main Q, is it safe to just insert a relay in between the main cables coming out of the generator so that I have no output to the capacitors and sockets at low rpm?
thinking about it, when turning off the generator from the helm and looking at the V meters, on dying and with the rpm lowering there's a peak in the V followed by a graduate drop to zero. But that peak can be in excess of 260V! I know I should remove load before turning on and off but I v.rarely bother tbh.
side Q, is there an easy trick to get a 12V charging circuit on that thing, or I just plug my Victron 12V15A charger permanently so that it charges the battery when the thing is running? Alternatively, find a cheap alternator and stick it on the yanmar (just a simple pulley to tension the water pump belt at the moment in it's place)
so what do you think?
cheers
V.
cheers
V.
