gavin400
Boat launched a couple of weeks ago, but so far have been unable to get the Volvo md1 to start.
The fuel tank has been removed to pressure wash/steam clean and the primary and secondary filters have been replaced.
The fuel system has been bled up to the connection to the injector and there is an ample supply of clean fuel to this point.
The air filter ls clean and there is nothing blocking the inlet.
There appears to be ample compression - i.e. it wont crank over by hand or battery with the valve lifter down, but spins freely with the lifter in the raised position.
Have checked that the throttle is operating, have tried with the cold start engaged and disengaged.
I have tried spraying Easy Start into the air inlet whilst cranking.
Nothing I have done is producing even the slightest indication that the engine will fire, it just seems completely dead - no wisps of smoke, no splutters.
The engine has always started immediately, either by hand crank or via the ignition and I have never encountered these problems
A suggestion has been made that I should remove the injector for checking, but I can't get it out and am wary of causing damage
All suggestions gratefully recieved
Many thanks
Gavin
Many thanks
Gavin
