john_morris_uk
If youve got the injector out, does that mean you'd like me to bring my Diesel Engine Compression tester back up to Scotland when I fly up on Sunday evening?
Watch out as unlike petrol engines diesel compression testers will only be of use if you have the correct adapter which is like a dummy injector
Hi,
if it helps I have a spare injector that you could try....but beware....they come in two lengths for the MD1....I know as I have both !!
PM me if you would like me to send one up to you to try....
All the best.
I strongly agree. Any diesel shop and most any good garage should be able to check the injector spray pattern and function. Checking it shouldn't be more than a few £. I would be verg surprised if it was anywhere near £50. That should nearly buy you a new injector! They should/might be able to do it on the spot.If your injector nozzle is partially blocked then fuel will be dribbling out rather than spraying in a fine mist which will make it unlikely to start. Take that injector for a nozzle spray test & cleaning/ replacement. It isn't that dear 20-50 quid at a guess depending on if it only needs cleaning or replacing.
