tom52
I read the advice in the similar thread (Oct/Nov 03) and tried to cure my leak by replacing the pump shaft seal 'in situ'.
Unfortunately this did not work. So maybe the shaft is worn and I now have to remove the pump. I have tried and failed.
The Jabsco pump is secured to my 1995 vintage Volvo MD 2020B by four bolts.
Two have their heads at the front of the pump and are no problem. The other two have their heads behind the pump and are threaded into the body of the pump.
They are inaccessible without some major engine dismantalling. Or so it appears to me, am I missing something?
I am reluctant to embark on further dismantalling to access the pump bolts without a workshop manual for the MD2020. The local Volvo agent says that individual maintenance or installation manuals for each seperate engine system fuel, transmission, electrics etc, are all that is available.
Any advice on the problem of removing the pump or the availability of a DIY workshop manual for the MD2020 would be greatly appreciated.
